Author: Subject: oil changing in R1
daniel mason
posted on 23/5/09 at 07:08 PM Reply With Quote
oil changing in R1
started the mnr this morning and oil can on spa guage is flashing along with red LED light. after reading instructions it indicates oil level has dropped. am i better to drop all oil and re-fill with correct ammount.or just top up existing oil. dont want to over-fill. if i drop oil is there a correct ammount for 5jj R1?
maximill666
posted on 23/5/09 at 07:17 PM Reply With Quote
I would ask Tim when the oil & filter was last changed & what oil he used, if its been done recently just top up with the same oil to the top of the sight glass window.
If it hasnt been done recently, just change the oil & filter for your own piece of mind, best use a gen yamaha filter(£10ish) & semi synthetic (£30ish)
A yamaha mechanic once told me the R1 clutches dont really like fully synthetic & it would probably slip, but IMO that might depend on if its got a heavy duty clutch spring or a coil spring conversion fitted.
Workshop manual says 2.7 litre with filter change, I have just done mine & it took 2.7 to the top of the sight glass window.
[Edited on 23/5/09 by maximill666]
daniel mason
posted on 23/5/09 at 07:24 PM Reply With Quote
cheers lee. hows the car coming on?
maximill666
posted on 23/5/09 at 07:35 PM Reply With Quote
All finished now mate, I picked it up from MNR a fortnight ago, had a few issues but all sorted now. It looks fantastic, very pleased
daniel mason
posted on 23/5/09 at 07:43 PM Reply With Quote
did you put reverse in it?
maximill666
posted on 23/5/09 at 07:46 PM Reply With Quote
No, but I have requested one to be fitted when Chris & Marc have their one in production.
