Author: Subject: twin 40's
austin man
posted on 26/5/09 at 09:42 PM Reply With Quote
twin 40's
carbs have been running okay then suddenly one plug starts to foul up turned mixture screw in still runs rich any ideas ?? was thinking could be a bit of crap in the carb any other ideas
Confused but excited.
posted on 26/5/09 at 10:12 PM Reply With Quote
Swap 'em for TBs?
austin man
posted on 26/5/09 at 10:30 PM Reply With Quote
thinking about bike carbs any suggestions
tomgregory2000
posted on 27/5/09 at 07:19 AM Reply With Quote
keep the twin 40's and just give them a clean
Mr Whippy
posted on 27/5/09 at 10:09 AM Reply With Quote
ditto, just take them apart and clean them. Do make sure you have good fuel and air filters fitted. Blocked jets tend to starve the engine off fuel so it’s unlikely to be that.
Also check the cold start system is turning off and that the fuel float needle valve is sealing properly, might be worth shaking the float to see if its been filling a bit with petrol and sinking. That’s quite a common problem with carbs and often noticed on bumpy country roads. If it is, simply place it on a radiator and the fuel will evaporate out. Some epoxy will seal any pinholes.
austin man
posted on 27/5/09 at 08:30 PM Reply With Quote
removed the jets today gave the carb 100psi through an air line and voila all sorted, cheers for your comments and advice
