theconrodkid
| posted on 28/5/09 at 11:29 AM |
zetec manifold gasket
running throttle bods on my zetec,the manifold gasket is steel with lines of sealer round the inlet ports...the ports are connected to each other via
the lines of sealer,has anyone blocked these air ways off or should i leave them as they are?
who cares who wins
pass the pork pies
hughpinder
| posted on 28/5/09 at 12:02 PM |
I'm not sure if this is what you mean, but the original zetec manifold I have has a ring round each inlet. I was planning to effectively connect
the ports on mine, as the idle valve plumbing will be open between inlets
Regards
Hugh
UncleFista
| posted on 28/5/09 at 02:00 PM |
Ours is on bike carbs, but I blocked the airways up with a blob of silicone. Seems fine
[Edited on 28/5/09 by UncleFista]
Tony Bond / UncleFista
| posted on 28/5/09 at 02:36 PM |
I used gasket paper and made me own.
will121
| posted on 28/5/09 at 02:59 PM |
think the link between the ports may have something to do with the crank case breather system which goes into the injector plate on the standard zetec
manifold, so if not being used shouldnt be a problem blocking it off
theconrodkid
| posted on 28/5/09 at 03:25 PM |
cheers peeps,i block them off
who cares who wins
pass the pork pies
