Author: Subject: pinto oil pressure readings?
FASTdan
posted on 31/5/09 at 01:55 PM Reply With Quote
Can anyone tell me what a pinto should be reading when hot, at idle and at high rpm?
Just installed a gauge and its reading 50+ all the time which seems high to me - wondering if the gauge is faulty.
SteveWalker
posted on 31/5/09 at 02:53 PM Reply With Quote
From memory, Mines roughly 60-70 cold, 20 hot. Which seems reasonable, but I can't remember what the figures should be.
goaty
posted on 31/5/09 at 05:54 PM Reply With Quote
mine is running 20w 50 valvoline, 50ish cold and 30ish hot both at idle.
hope it helps
FASTdan
posted on 1/6/09 at 06:52 AM Reply With Quote
hope it helps
That sounds similar - mine was showing mid 40's this morning with oil temp around 60degs which still isnt that hot.
jpindy3
posted on 1/6/09 at 09:34 AM Reply With Quote
how much diffrance would a high pressure oil pump make to the reading?
[Edited on 1/6/09 by jpindy3]
DarrenW
posted on 1/6/09 at 12:03 PM Reply With Quote
Just put mine back on the road today. Showing 70psi cold and about 60 ish hot.
FASTdan
posted on 1/6/09 at 12:31 PM Reply With Quote
At idle?
jpindy3
posted on 1/6/09 at 02:06 PM Reply With Quote
mine is in bar its 6bar cold @ idle 87psi,
and 5bar when worm,it has a high pressure oil pump,wether that makes a big diffrence i dont know?
DarrenW
posted on 1/6/09 at 02:46 PM Reply With Quote
At idle?
yes, at idle. Havent took a lot of notice what it runs at hot. Im just happy that ive got some!
goaty
posted on 1/6/09 at 05:35 PM Reply With Quote
what sort of oil temp would be said as ideal??
DarrenW
posted on 1/6/09 at 08:40 PM Reply With Quote
My oil temp more or less follows the water temp, just takes a bit longer to get there. There was a thread on here ages ago that discussed this in detail. In summary (from memory) it was said that it was god for oil to get to around 100 degs to boil off any condensation. Might be worth a seperate thread as this type of question can promote lengthy discussion.
FASTdan
posted on 2/6/09 at 07:04 AM Reply With Quote
Most oil cooler thermostats open at 80deg. Haynes also quote oil pressures at 80deg (for my XR2 anyway) so I've always been under the impression 80 is a reasonable operating temp.
goaty
posted on 3/6/09 at 06:45 AM Reply With Quote
thats good, as mine peeks at about 80, just takes a while to get there.
cheers
flak monkey
posted on 3/6/09 at 06:47 AM Reply With Quote
With a high pressure and high capacity pump mine idles at about 40psi hot (110psi cold) and under power runs at just over 100psi hot.
That is on 10W60 fully synthetic
Sera
http://www.motosera.com
