Author: Subject: take 2 iva
jpindy3
posted on 3/6/09 at 07:18 PM Reply With Quote
take 2 iva
got my retest,in the morning,i only had 7 things to sort out,edges,reverse light,and a sticker to show what brake fluid it takes,the make of the car on the plate,also the lights i got from rally disigen the beam flicked up the wrong way,thats the 4in ones so watch it,
jamie
sorry the vin plate
[Edited on 3/6/09 by jpindy3]
speedyxjs
posted on 3/6/09 at 07:20 PM Reply With Quote
Good luck
What plate do you need the make of the car on?
RichardK
good luck my friend.
Rich
Gallery updated 11/01/2011
blakep82
posted on 3/6/09 at 07:59 PM Reply With Quote
good luck! you deserve it
how long does it take to get a IVA booking now?
________________________
Macbeast
posted on 3/6/09 at 08:02 PM Reply With Quote
Sticker to show what brake fluid ???
Bloody hell !
do you need sticker to show tyre pressures ?
[Edited on 3/6/09 by Macbeast]
Daddylonglegs
Good luck
andylancaster3000
posted on 3/6/09 at 08:06 PM Reply With Quote
Is this the first known LocostBuilders IVA attempt or am I far too far out of touch?
Good luck btw!!
[Edited on 3/6/09 by andylancaster3000]
andy188
posted on 3/6/09 at 08:41 PM Reply With Quote
good luck,
whats this make on plate?
jpindy3
posted on 3/6/09 at 08:59 PM Reply With Quote
Bloody hell !
if you look under the bonit of a normal car by the brake fluid res you will see a yellow sticker,it lokks kind of like this
(o)
you can just draw it on somthing yellow,and draw it in black,as long as it dont come off you will be ok
oh its the make of the kit,my engilsh is bad sorry,
thanks you lot
l0rd
posted on 3/6/09 at 09:48 PM Reply With Quote
Bloody hell !
No but what sort of fuel you are using i believe should be indicated.
hellbent345
posted on 3/6/09 at 10:11 PM Reply With Quote
what happens if you are build an own design? or something like a haynes roadster with serious chassis mods?
iank
posted on 3/6/09 at 10:14 PM Reply With Quote
Bloody hell !
(o)
thanks you lot
Symbol is in the May 09 IVA manual on page 86
or depending on your reservoir you can use a cap with the symbol on it and the DOT type of the fluid (which makes sense as you shouldn't mix different DOT fluids (especially silicone with any other).
Like this one
http://cgi.ebay.co.uk/MERCEDES-BENZ-BRAKE-RESERVOIR-CAP-NEW-A2024300014_W0QQitemZ370204638725
Maker's plate means you need a plate with chassis number and manufacturers name on it.
Page 135 of the May 09 manual has the regulations.
Not clear if it's the manufacturer of the kit or the person that screwed it together, I suspect the former.
[Edited on 3/6/09 by iank]
Anonymous
bob
posted on 3/6/09 at 10:31 PM Reply With Quote
Good luck mate hopefully se you at newlands corner next month, i presume your test is at Mitcham.
MautoK
posted on 3/6/09 at 11:25 PM Reply With Quote
Good luck Jamie!
matt_claydon
posted on 4/6/09 at 06:58 AM Reply With Quote
Make is entirely up to you, but it should be the same as what you want on the V5.
If you have built from a recognised kit (MK, MNR etc) then your car will be worth more if you put that on the plate / V5.
iank
posted on 4/6/09 at 07:55 AM Reply With Quote
Thanks for the clarification Matt, putting Caterham on would make it worth even more, wonder if they have thought about future fraud?
Anonymous
