dewbries
| posted on 4/6/09 at 07:12 AM |
Loss of power
Running zx9r c1 carbs piper cross filter all set up by Boggs. Not had time to take it back but have spoke to them on the phone wonder if any body has
ideas in the mean time. Car runs fine pottering around but if I want to really give it some, drop it down and pass someone, it climbs to around 4000
and then starts spluttering, and I think by the smell spits petrol out the carb. If I back off it will recover and slowly continue to rev but can not
get it over 6000.
Any ideas? Cheers guys.
Second build. Now refining and changing drive train
Mr Whippy
| posted on 4/6/09 at 07:17 AM |
either fuel starvation or the timing is out
does it do this while reving it stationary or only under load? if only under load I'd say that was the high speed jets are blocked, otherwise
the timing advance is not working
ReMan
| posted on 4/6/09 at 07:23 AM |
The symptoms of not running an airbox
Mr Whippy
| posted on 4/6/09 at 07:40 AM |
? why, don't see what difference it should make to carbs
ReMan
| posted on 4/6/09 at 12:44 PM |
Bike carbs in many cases seem to prefer "still air" accross them. rtaher than turbulent air. Discussed here many times before.
My own experiece is exactly that reported, would not rev out atall even at standstill, with the dynojet kit fitted so plenty rich enough. Put the box
back on with new K+N freeflow filter all good again
Mr Whippy
| posted on 4/6/09 at 01:34 PM |
hmm interesting
dewbries
| posted on 4/6/09 at 03:25 PM |
Don't think timing is out as it would rev with the Weber 40's I had on, about the only thing it would do well. Running omex ignition so
advance is programmed into the map.
Not heard of the still air problem!Don't know whether this would make a big difference but the filter sticks out through the bonnet.
[Edited on 4/6/09 by dewbries]
jacko
| posted on 4/6/09 at 06:55 PM |
Is your air correction holes blocked if not the fuel / air will go week at high revs
http://www.locostbuilders.co.uk/viewthread.php?tid=114740
dewbries
| posted on 4/6/09 at 10:38 PM |
Holes block at Bogg brotheres.
