Daddylonglegs
| posted on 4/6/09 at 04:24 PM |
2.0 l Pinto EFi
Thoughts on fitting a 2l Pinto Efi (with power stering (but I don't need that bit )
Will it go straight onto my type 9 from a 1.6 Pnto?
JB
speedyxjs
| posted on 4/6/09 at 04:25 PM |
Pinto's a pinto isnt it?
deezee
| posted on 4/6/09 at 04:32 PM |
Yes, a type 9 mates with all engines, ever.
blakep82
| posted on 4/6/09 at 04:35 PM |
^ kinda, some will need a lot of work, though i'm not sure about this one
but, yes, they're both pinto blocks.
[Edited on 4/6/09 by blakep82]
________________________
dogwood
| posted on 4/6/09 at 04:59 PM |
JB
If you decide to go ahead with the engine change, let me know how you get on.
I would be interested in any bits you need to change, or problems you come cross.
I have got a 2L efi Pinto waiting to go in after the summer.
FREE THE ROADSTER ONE…!!
deezee
| posted on 4/6/09 at 05:02 PM |
Yeah Blake, the electronic ME engine, a type 9 will deffo go onto that, just need a clutch release bearing off a 1918 Rolls Royce silver ghost, which
used the earlier Type 9.
[Edited on 4/6/09 by deezee]
Mark Allanson
| posted on 4/6/09 at 05:31 PM |
You can keep the injection and save £££ on carbs too
snapper
| posted on 4/6/09 at 05:56 PM |
If you fit injection you will need an injection fuel pump and will need to make sure all the rubber pipes are upgraded to injection fuel pipes as the
old carb rubber ones can explode under the pressure.
You will need a return fuel feed and probably a swirl pot.
I eat to survive
I drink to forget
Daddylonglegs
| posted on 4/6/09 at 07:21 PM |
guess I'll be fitting my old 1.6 E-max then (unless anyone's got an easier 2l they want to clear out of the garage )
Mark Allanson
| posted on 4/6/09 at 07:24 PM |
Why give up?, I would say the injection route is easier than most others.
mcerd1
| posted on 4/6/09 at 07:37 PM |
the efi engine works just as well on carbs
so if you do give up on the efi - throw it in the bin and stick carbs on it (like I'm doing with my 2.0 efi pinto )
[Edited on 4/6/09 by mcerd1]
Mark Allanson
| posted on 6/6/09 at 09:40 AM |
"the efi engine works just as well on carbs "
I am not knocking carbs, but my car regularly does over 50mpg when in grown up mode, starts first time every time on the first rotation of the engine,
and the emissions are in the cat class, CO at 0.5% and HC at 78ppm
The other advantage is you already have the injection system so not much additional outlay
mcerd1
| posted on 6/6/09 at 10:03 AM |
I'm not knocking EFI - Its just that the electrics scares me :lol:
but which ever way you want to go
(down/sidedraft carb(s), bike carbs, Ford EFI, ITB's, bike ITB's.......)
the 2.0 EFI engine is probably the best standard Pinto to get
the EFI engine has got slightly stronger conrods, a stronger block and a better standard port shape in the head
and there is nothing to stop you fitting carb's and any dizzy you like to it
[Edited on 6/6/09 by mcerd1]
