Daddylonglegs
| posted on 7/6/09 at 04:34 PM |
Block Identification
SImple one (hopefully).
What is the difference betwen a pinto 2L with a 205 block, and one with a '2.0' block?
And is the 2.0 block worth getting?
JB
omega0684
| posted on 7/6/09 at 04:36 PM |
the 205 block is slightly stronger as it has extra 'webbing' at the back of the block.
thats about it
the pinto im rebuilding at the moment has a 2.0 block and i have a 205 in my car, not a lot of difference, IIRC correctly the 2.0 blocks were with the
earlier pinto, pre 84 i think, then the 205 came out and that is what they use in the cossie applications as well
[Edited on 7/6/09 by omega0684]
tomprescott
| posted on 7/6/09 at 05:15 PM |
Thats how I understand it too, with the 205 having 205 in raised letters on the side for identification. I think if you get an EFi engine they are 205
block - but not 100% sure.
mcerd1
| posted on 7/6/09 at 05:24 PM |
like they said ^^^
most 205 blocks have '205' in very large letters on the sides
like this:
  Pinto - 205 block
or like this:
  pinto - 205 block
but you should only need the extra strength / thickness if your going to stick a turbo on or bore it out to a 2.1
on the other hand most 205 blocks will have the stronger late style conrods inside
also have a read at this:
http://www.siipicossu.com/manuaaleja/how_to_power_tune_Ford_SOHC&DOHC.pdf
[Edited on 7/6/09 by mcerd1]
