jpindy3
| posted on 7/6/09 at 10:34 PM |
any iva questons il try and help
hi there i passed my iva a cupple days ago,there are a few changes from the sva,but if there is any thing you are stuck on il try and help you
jamie
sorry lads post all questons on this tread please
[Edited on 7/6/09 by jpindy3]
[Edited on 8/6/09 by jpindy3]:
Dick Axtell
| posted on 8/6/09 at 09:30 AM |
U2U sent - probably the first of many!!
cd.thomson
| posted on 8/6/09 at 09:39 AM |
Jamie, would you mind posting the q+a's in here? That way you wont have to answer the same questions over and over - people can look at this
thread.
Fozzie - could you move this to the IVA section? Could be sticky if it picks up some steam
My question is - did you have an radius issues with your front suspension/hubs?
[Edited on 8/6/09 by cd.thomson]
Craig
jpindy3
| posted on 8/6/09 at 06:48 PM |
Thanks for ur offer re info. I know that I'll have to change from plastic fuel tank to metal (probably alloy), but not sure about other
"extras" wrt SVA requirements.
Have heard that a) exhaust silencer has to be guarded with heat shield,
b) the ign electrics have to be protected against water ingress, e.g. distributor fitted with, errrr, some kinda condom (or other rubber cover).
Are these points accurate? Any other things to prepare for, in addition to known SVA stuff?
[answer]
no gaurd,i didnt have one.
yes us a durex extra thick,ribbed works better,a little tip use strewberry flaver you get a nice smell when driving.
only kidding,
no,i didnt have any water proofing on or around the dizzy.
jpindy3
| posted on 8/6/09 at 06:49 PM |
thread.
yes this was one of the things i failed on first time,
1.the top crowns on the shockers i had to file the edges,my shocks are pro shock so if you find a pick of one you can see that the edge isnt atall
sharp,and could easyly be missed.
2.the bottom spring ajuster,the bit you use a c spaner on again filed.
3.the rebound ajusting knob,i used a gromit that fitted over it.
4.make sure the spring ends can not be contacted with the ball.if so file them.
5.the hubs them selves were fine put a gromit over the brake fluid inlet banjo bolt
good luck
jamie
jacko
| posted on 8/6/09 at 07:02 PM |
Is the front indicators ok on storks or do they have to go on the front mud guards ?
asking for a mate
Jacko
jpindy3
| posted on 8/6/09 at 08:03 PM |
asking for a mate
Jacko
hi jacko,i had the front indicators that are on storks fitted to the nose cone,as nomal,but i put the side repeaters on the front wings,not on the
scuttle
make sure the stalks are long enuff,to meet the lighting regs
cd.thomson
| posted on 9/6/09 at 10:19 AM |
thanks for the reply jamie
Craig
40inches
| posted on 11/6/09 at 12:31 PM |
Do you have the Sierra master cylinder fitted, if so did you have any problems with the brake test?
jpindy3
| posted on 11/6/09 at 07:09 PM |
the brakes are fine,the sierra brakes are made to stop a sierra so thay stop a kitcar on a penny,thay will lock up on the test witch is a pass,and
thats what you want
