jpindy3
| posted on 9/6/09 at 07:08 PM |
high pitch skweek,from a bore
hi there,i was checking the valve clearances and i took the plugs out so its not as hard to turn over,and i noticed a high pitch skweek coming from
cly 4 as im turning it over,
anyone had this should i worrie??
oh its a pinto
the only thing i can think it is is a ring thats broke
[Edited on 9/6/09 by jpindy3]
jpindy3
| posted on 9/6/09 at 07:49 PM |
anyone
lotusmadandy
| posted on 9/6/09 at 07:50 PM |
I have had this on a pinto before,
it turned out to be the ring squeeking
as the the piston came up the bore.
It was nowt to worry about.
Do a compression test to check if you are worried,
that will tell you if you have a problem.
I did this recently and found non existent
compression on no 2 cylinder, i had to rebuild it.
jollygreengiant
| posted on 9/6/09 at 07:52 PM |
Sounds a bit like high pressure bleed, past rings, or simmilar. I pressume that it occured as you got to maximum resistance to turning over.
Beaten to it but nowt to worry about.
jpindy3
| posted on 9/6/09 at 07:54 PM |
thanks andy,your right its when it coming up the bore,i was gona cheack the cr tomorrow ,
thanks jamie
