Author: Subject: sump plug
Stuart_B
posted on 10/6/09 at 08:11 PM Reply With Quote
sump plug
hi all, the sump plug on a pinto engine, is there one out there, which have a thread hole for a temp sensor in it, or can i just drill and tap a hole in a center of a standard one?
thanks
stuart
posted on 10/6/09 at 08:17 PM Reply With Quote
Burton power do a drilled sump plug.
Also Halfords do a varity of sump plugs.
if push comes to shove, you can always use a bolt - sump plugs differ as they have a larger head and an undercuit for the crush washer.
Stuart_B
posted on 10/6/09 at 08:26 PM Reply With Quote
thanks, i will have to get one.
stuart
posted on 10/6/09 at 08:33 PM Reply With Quote
Just drill & tap I did a Rover 45 one last week it was a relatively easy job.
