Author: Subject: nexted,how to fix a trigger wheel
jpindy3
posted on 10/6/09 at 08:33 PM Reply With Quote
i have a ring gear type trigger wheel,and i need to fix it,how have you lads that are useing on fix it to the crank pulley??
thanks again
omega0684
posted on 10/6/09 at 08:36 PM Reply With Quote
take the crank bolt out, put it through the centre of the trigger wheel and bolt it on in the correct position in relation to the sensor.
job done
jpindy3
posted on 10/6/09 at 09:05 PM Reply With Quote
job done
no i have a ring gear type!
jpindy3
posted on 10/6/09 at 09:20 PM Reply With Quote
dont matter i just got another one off ebay,the type you put a bolt through
Thinking about it
posted on 10/6/09 at 09:22 PM Reply With Quote
Come on Alex read the question
major
posted on 11/6/09 at 04:34 AM Reply With Quote
Sometimes the flywheel is used as trigerwheel by drilling small 36-1 holes on the side!
flak monkey
posted on 11/6/09 at 06:48 AM Reply With Quote
Not a good idea as it will upset the balance! All well and good if it was designed that way by the manufacturer, but not a diy mod!
Sera
http://www.motosera.com
mcerd1
posted on 11/6/09 at 08:23 AM Reply With Quote
thanks again
a bit late now but...
to fit a ring type one most people stick the crank pulley in a lathe and make a bit for the ring to sit on, then bolt or wels it on (welding doesn't always work - depends what the pulleys made of)
you should be able to get a pulley rebalanced for £15 - 20
or you can get a custom / aftemarket pulley thats made to fit a trigger wheel
[Edited on 11/6/09 by mcerd1]
omega0684
posted on 11/6/09 at 10:48 AM Reply With Quote
and tell the nice people how much yours cost rob!
Richard Quinn
posted on 11/6/09 at 11:02 AM Reply With Quote
job done
Using a big washer!!
mcerd1
posted on 11/6/09 at 12:17 PM Reply With Quote
all I'll say is, as a 1 off its the about the same as one of uncle Ron's cars
if I made 100 of them I guess they'd be a a bit cheaper than the cossie WRC ones on ebay
major
posted on 12/6/09 at 04:51 AM Reply With Quote
And balance the flywheel afterwards offcours!
jpindy3
posted on 12/6/09 at 09:51 AM Reply With Quote
thanks lads,its my fault i thort there was more meat on the ring gear one so i could tap it,the other way would have been get a steel pulley but thats 50quid,so for another 20 i got one with a 11mm hole in the middle,i will also tap 4 holes into the steel thick washer in the middle of the pulley,so if any one wants a ring gear type i have one
