Author: Subject: r1 emissions
markyb
posted on 10/6/09 at 11:03 PM Reply With Quote
r1 emissions
having failed my SVA retest on emissions (03 r1) I am trying to work out where the powercommander mapping is wrong - my readings are
co = 4
hc = 4
lamda = forgot to ask
in real terms what do these figures mean the engine is doing and how do I get them nearer the correct reading?
I did take the car to a rolling road for an SVA map so was hoping the emissions would be fine. As this failed I am looking at tweaking things myself but need to understand the whole emissions thing first to make sure I follow the correct path
thanks for any help
Davey D
posted on 11/6/09 at 05:06 AM Reply With Quote
didnt the sva tester give you the printout from the emissions test?
markyb
posted on 11/6/09 at 06:11 AM Reply With Quote
nope - didnt realise I could get one - I didnt see a printer at the machine (unless it prints off in some back office somewhere)
adithorp
posted on 11/6/09 at 07:19 AM Reply With Quote
Sorry, but those numbers don't mean a lot!
Test is
Fast idle (2500-3000rpm).
CO <= 0.3%,
HC <= 200ppm,
Lambda between 0.97 - 1.03
Idle test(450 - 1500prm),
CO <=0.5%
Hard to know what your is. If that CO figure is 4% it's rich and/or the cat's not working/up to temp (Been covered several times so do a search in IVA/legal). Can you get it to an MOT station and ask them to do a BET's test on the emmisions (same as IVA test)? Have you tried phoning the test station and asking for a copy of the test result?
adrian
http://jpsc.org.uk/forum/
spdpug98
posted on 11/6/09 at 07:31 AM Reply With Quote
I am happy to send across the SVA map which my 03 R1 passed with, it was a map from someone else but it failed on my car, so I tweaked it a bit
My Blog: http://spdpug98.wordpress.com/
markyb
posted on 11/6/09 at 09:09 AM Reply With Quote
the tester didnt record the actual figures as the readings were so far out - it was that bad that the testing machine stopped working so he tried another machine and that broke too !!!
I did ask for the figures at the end of the test and thats when he told me 4% and said that all 3 failed (CO, HC and lambda).
I had thought that I had got the cat upto temp (part of the testing equipment melted during the test) but will look at it again
I will try and get my hands on a gas analyser so that I can spend time on doing tests myself to see if I can identify the problem
spdpug98 - thanks for the offer of the map but will hold off until I can see if I can trace the problem in case my own map is ok
dan__wright
posted on 11/6/09 at 11:16 AM Reply With Quote
your running very rich, i broke one machine and melted another at mot test stations trying to get them sorted for sva
Richard Quinn
posted on 11/6/09 at 11:42 AM Reply With Quote
Take the offer of the map and compare it with yours. You don't have to use it.
twybrow
posted on 11/6/09 at 11:49 AM Reply With Quote
Get to your local MOT centre, and ask to use their machine for some beer tokens. Just don't melt their probe (still awiaitng a bill from my local mot centre!).
Remember, you can now drive it to somewhere to get this sorted. As others have said, it sounds like it is rich - can you borrow a wideband lambda sensor to check? I found once I had the lambda spot on (lambda = 1, afr = 14.7) , the emissions dropped well within limit.
markyb
posted on 11/6/09 at 03:01 PM Reply With Quote
all mot centres in Northern Ireland are state run so dont think anyone would risk their job for a few beer tokens - I will try a few local garages to see if they have the right machine and work from there.
I do have a few different maps from a while back so will compare them to my rolling road map to see if they are anyway close
