<<  1    2  >>
Author: Subject: cheap nasty engine
locoboy
posted on 11/6/09 at 06:33 AM Reply With Quote
cheap nasty engine
Guys,
Im planning a new build and im looking at putting in a real cheap old engine to get through IVA and the swap it out for a bike engine.
I have been on here long enough to have heard the reaction of many to this concept but im coming round to the idea now.
I know it will be more work in the long run but i dont want to have to faff with emissions and i need to buy myself some time financially before i can commit to completing a bike installation.
So what im after is ideas of a cheap small easy to wire rwd enigne / gbox combo.
I wil be building the car with the swap in mind so a sacraficial side pannel will be installed that that can be removed after the test and the original pannel fitted back on and exhaust hole cut out, any lower engine mounts will be put in where possible, centre beaing mounts etc, all to lessen the work after the IVA test.
Ideally i would like an engine choice that does not need a hole cut in the bonnet for a carb.
Thanks guys
Col
Locoboy
mad4x4
posted on 11/6/09 at 06:42 AM Reply With Quote
What about a PINTO then - Cheap and Nasty
Scot's do it better in Kilts.
LBMEFM
posted on 11/6/09 at 06:44 AM Reply With Quote
Fit a Sierra engine & Gearbox driving through a Sierra Diff (3.62) if poss. Then keep the diff and fit a bike engine at a later date in a cradle. This goes straight in to your chassis and connects to Sierra diff with the aid of a modified prop and adaptor plate for the engine output. Simples
Guinness
posted on 11/6/09 at 06:55 AM Reply With Quote
What about an A series? or are these getting expensive these days?
Mike
alistairolsen
posted on 11/6/09 at 07:01 AM Reply With Quote
smallblock 1.6 8v vauxhal engine with a manta/omega box.
Need about 5 wires to run, amke around 100bhp
Steve G
posted on 11/6/09 at 07:02 AM Reply With Quote
Plenty have passed SVA with bike engines and it seems such a huge amount of work to do the transplant later on just for the sake of sorting the emmissions and noise. I recon if you really want to look at fitting a pre Aug 95 engine in order to get simpler emmissions levels to meet, then a CBR1000 or early ZX9R engine would surely be a better option. I wouldnt mind betting this sort of engine complete with electrics and maybe clocks could be had for well under £500, but would then enable a much simpler conversion to a later engine to be done. The loom can be kept to an almost modular format with all the lights and so on seperate to the engine loom, with only 3 or 4 connections to make between the two. The prop can then remain the same, with the only real concern being the reverse requirements.
x_flow57
posted on 11/6/09 at 07:03 AM Reply With Quote
Would something like this fit the bill?
Cheep not so nasty engine.
Nick
Daddylonglegs
posted on 11/6/09 at 07:20 AM Reply With Quote
I resemble that remark!
wilkingj
posted on 11/6/09 at 07:22 AM Reply With Quote
Make sure the engine is old enough to warrant not being tested for Emissions at MoT.
Still... It will need to get thru the emission test for the IVA, so it needs to be in reasonable condition to do that.
I like your strategy.
Best Regards
Geoff
http://www.v8viento.co.uk
iank
posted on 11/6/09 at 07:33 AM Reply With Quote
Caterham used those on their base models for a while before the K series iirc. Should cost around £50 for a good one with a free car to give to the scrap-man to get your money back.
Ford engine and type 9 is probably the more obvious route though.
Anonymous
posted on 11/6/09 at 07:35 AM Reply With Quote
as said, many have passed with a bike engine.
if you want cheap and nasty, you can pick up running ford crossflows for small money.
advantage over pinto is that is is smaller, lespecially heightwise so you won't need to modify bonnet, lighter and exhaust leaves on same side as bike engine.
... and them come in under 15495 cc in size so you can be paying less tax and prboably insurcance whilst saving up for the BEC transplant.
[Edited on 11/6/09 by 02GF74]
Humbug
So you're cheap and nasty as well? or do you resent the remark?
AndyGT
I agree small block 8v vauxhalls are cheap as chips but manta boxes and sumps are now getting expensive.
The old ford crossflow route is hard to beat as they are cheap as chips to do and you could fit any 1.1, 1.3 or 1.6 model. Mounts are very easy to source as this was the book car. But I would use IRS from a sierra.
As for bile engines, the BIG problem to somve with a small budget is the reverse gear. Si CEC pre IVA and BEC after sounds like a very fair idea...
Good luck anyway
johnemms
posted on 11/6/09 at 07:52 AM Reply With Quote
Belive it or not.... I use cataclean .. It reduces petrol and or diesel emissions by up to 60%
I just mot'd my old w reg 2.0hdi .. same cat since i bought and welded it up years ago..
1 bottle of cataclean .. run it for a few miles... presto.. pass....
I intend to drop a bottle in if i ever get to iva... i have total faith in it.. :p
Oh .. gotta put my 2.4 petrol previa 15mpg through this month.. with dodgy mass air flow sensor.. not worried.. got a bottle on the table here ready for that..
www.cataclean.com i get mine from GSF brum unless you can find or order some in at your local factor...
remember.... i 'only' use it on the day of the mot.. tc...
PS.
first use..
My 9 yr old 2.0hdi failed emissions big style... put bottle in .. re test.. easy pass..
previa 2.4. failed..told i need expensive airbox - mass airflow unit .. put bottle in.. re test easy pass..
[Edited on 11/6/09 by johnemms]
mark chandler
posted on 11/6/09 at 07:53 AM Reply With Quote
893 fireblade, made in 1992 so misses the emmisions rules and will cost circa £400 for a good one.
Job done, and it will be quick and require little work to upgrade.
owelly
posted on 11/6/09 at 08:16 AM Reply With Quote
As said, the bike engine pre IVA is a no go due to the need for a reverse.
I suggest finding or borrowing whatever Ford stuff you can get your hands on. It's been fitted to everything and anything so any problems are long gone.
http://www.ppcmag.co.uk
iank
posted on 11/6/09 at 08:28 AM Reply With Quote
Nick
As it comes with a 'free' prop that seems ideal
Anonymous
Bluemoon
posted on 11/6/09 at 08:29 AM Reply With Quote
1.8 CVH?? people don't seem to like them, I have one can't see the problem (it is locost after all!) each to there own! Without an airfilter I have managed to get it under the bonnet without a cut out (had to machine inlet manifold though....
Personaly I would rather get a reverse and go for what you want rather than making even more work for yourself.. Also not having a reverse might cause insurance trouble if you had to have this fitted for IVA?? I would check this out first..
Dan
[Edited on 11/6/09 by Bluemoon]
TimC
Nick
I honestly think that the installation is a good deal. Everyone is telling me that I'd probably get more for it if I sold it seperately but I haven't the time to deal with numerous eBay enquiries. Therefore the cost to you could be negative (i.e. bring profit) if you were prepared to separate once you'd finished with it. One thing that I missed off the advert was the Facet solid state fuel pump!
[Edited on 11/6/09 by TimC]
minitici
posted on 11/6/09 at 09:10 AM Reply With Quote
Don't ignore the Reliant Robin 850 engine & gearbox as a 'mule' to get the car through IVA.
Light alloy and small, cheap, easy to obtain and a suitable age.
UncleFista
posted on 11/6/09 at 09:13 AM Reply With Quote
I vote for crossflow, visible smoke test only for the life of the car
Tony Bond / UncleFista
omega0684
posted on 11/6/09 at 09:28 AM Reply With Quote
OI! Sea Captains like myself take offence at you mocking my boat anchor!
James
posted on 11/6/09 at 09:31 AM Reply With Quote
It was a joke Simon!
Not a typo!
Daddylonglegs
posted on 11/6/09 at 09:48 AM Reply With Quote
Nope! I definitely meant resemble (it's a long story )
Daddylonglegs
posted on 11/6/09 at 09:49 AM Reply With Quote
Not a typo!
Correct sir
<<  1    2  >>
