Author: Subject: Accusump
alistairolsen
posted on 15/6/09 at 09:44 AM Reply With Quote
Accusump
Has anyone/does anyone use one?
Any experiences or opinions to share?
bimbleuk
posted on 15/6/09 at 09:56 AM Reply With Quote
If you have a genuine surge problem and track your car regularly they are a good measure and cost less than a typical dry sump installation.
If you use your car on road mostly then just put a bit more oil in!
I've been using mine for quite a while but now don't bother opening it when driving on the road. As I have the manual valve and its at the front of the engine bay I can't bother to take the bonnet off each time I stop the engine.
Only other issue on mine is if I don't pre-oil the engine with the accusump and let the engine stand the next time I start the engine on my setup the oil takes a few seconds longer to reach the usual idle oil pressure. Easy to avoid by shutting the valve before starting but again I have to remove the bonnet.
So if you have a need for one then I would highly recommend using one of the electronic valves (adds quite a bit to the cost though) or mount the Accusump so you can easily access the manual valve.
Justin
hobbsy
posted on 15/6/09 at 10:11 AM Reply With Quote
I heard that the electronic valves don't flow as well as the manual ones (unless they've improved them) so you may want to do some research around that area before deciding.
owelly
posted on 15/6/09 at 10:22 AM Reply With Quote
I have one fitted to a shelf in my shed. I got it to add capacity to my oil as I cut two inches out of the sump. However, the car has yet to suffer enough for me to fit it! I have two oil pressure gauges fitted. One from the top of the remote oil filter housing and the other from the top of the engine oil gallery. I've kept a close eye on both gauges when cornering hard but neither one drops. So it stays fitted to the shelf, despite having the pipes a nd brackets fitted to the car! But that brings me to the other reason why it never got fitted (before I realised it didn't need it)............
I couldn't decide where to plumb it in. Some say that it goes to the filter sandwich plate in the larger bore pipework, others say it needs to be direct to the oil galleries.
The leccy valves I sourced were small bore things but I intended to use quarter turn, full bore valves operated by cable once the system was up to pressure. The leccy one would open when the oil pressure switch told it to. That way it would pressurise once the demand to the engine was met. Once up to pressure, then I'd open the big valve. That was the plan.......
http://www.ppcmag.co.uk
bimbleuk
posted on 15/6/09 at 11:38 AM Reply With Quote
I was going to mention the base electric valve at the time I bought mine did indeed release oil quickly but re-filled more slowly. So on the road they were fine but on track between corners the Accusump may not re-fill sufficiently. I have heard the design was changed to fix this but you may want to check this to be sure.
alistairolsen
posted on 15/6/09 at 12:07 PM Reply With Quote
you get two typoes of electronic valves to cover both, one significantly more expensive than the other.
