Author: Subject: BMW gearbox bearings?
alistairolsen
posted on 21/6/09 at 11:54 AM Reply With Quote
I need to source some bearings for my BMW Getrag gearbox due to excess input shaft play. Does anyone know where I can source BMW parts at locost prices?
BigFaceDave
posted on 21/6/09 at 12:29 PM Reply With Quote
Not sure if this is any help but there is german french and swedish car parts ( www.gsfcarparts.com ) and also Eurocar parts ( www.eurocarparts.com ) which stock BMW parts that are not as bad as some places. Hope this helps!
theconrodkid
posted on 21/6/09 at 01:37 PM Reply With Quote
i believe they are unique to gartrag and not available to anyone not even BMW
who cares who wins
pass the pork pies
alistairolsen
posted on 21/6/09 at 01:52 PM Reply With Quote
BUgger! Wonder if theyre available direct from getrag...
posted on 21/6/09 at 04:00 PM Reply With Quote
If you have the box stripped take the bearing to your local bearing specialist , they may be able to help and be cheaper . Some play is normal in a first motion shaft if the crank uses a spigot bearing
alistairolsen
posted on 21/6/09 at 04:27 PM Reply With Quote
it does use a spigot bearing,but I deemed 0.75mm to either side of centre to be a bit excessive?
The bearings are out so i will give BSL a call tomorrow and see what they reckon.
