Author: Subject: new bottom end
jpindy3
posted on 22/6/09 at 02:54 PM Reply With Quote
new bottom end
right im building a new bottom end,this was the plan anyway but i wasnt going to do it for a while,i was going to turbo the vulcan engine dropping the cr so it could take some boost,but after that balls up i really dont think turboing it now is a good idea,its a fine line turboing a engine with cast pistons in,and i dont think it will be worth it now it may be damaged,
so i have a 202 block witch im getting rebored,and i have just payed for some new cossie pistons and rods,
has anyone done this convershon,
i know i need to fit a cossie oil pump as the pinto one dont have a spray bar to spray the bottom of the pistons,
can any one give me any pointers..
omega0684
posted on 22/6/09 at 03:24 PM Reply With Quote
mate if your going to do that get a 205 block, especially if you intend to turbo it, u2u mercd1 he has done a pinto with cossie bottom end.
don't bother buying a cossie crank just use the pinto one and get more dowels put in the flywheel end.
[Edited on 22/6/09 by omega0684]
jpindy3
posted on 22/6/09 at 03:43 PM Reply With Quote
err why a 202 is stronger,and low cr
engine number starting with NA is low cr so it a good start
[Edited on 22/6/09 by jpindy3]
mookaloid
posted on 22/6/09 at 03:51 PM Reply With Quote
As above use a 205 block for starters.
How much power do you want? there may be much cheaper ways of doing it
mookaloid
posted on 22/6/09 at 04:04 PM Reply With Quote
202 is even heavier than 205
it's a low CR ford transit block so I guess it's ok for a turbo installation.
I can't help thinking that there's a better/lighter/cheaper way of achieving more power than building a pinto from scratch and then adding the turbo.....
flak monkey
posted on 22/6/09 at 04:05 PM Reply With Quote
Yep, its called a NA Duratec I4
Sera
http://www.motosera.com
jpindy3
posted on 22/6/09 at 04:17 PM Reply With Quote
ok,
well im using the 202 block coz i have one,
and using the big valve head off of the vulcan,
i know its a little bit heavier bit it ant by much only a cupple of kgs,in a car that waighs 560kg it ant gona make any diffrance,
wouldnt you say,
also il be running alot more power than the vulcan so the little extra waight isnt going to matter
jpindy3
posted on 22/6/09 at 04:33 PM Reply With Quote
well i dont agree,if i was to get a new zetec and wanting 200bhp the engines are going for 700quid,then i would want some tb and and ecu and cams it will be a good 1500quid,
the pinto turbo with the cossie pistons will give more than 200bhp so for the buck its a safe bet
mookaloid
posted on 22/6/09 at 07:22 PM Reply With Quote
You got that right
Andy D
posted on 22/6/09 at 07:35 PM Reply With Quote
You got that right
Time to give my Pinto v Dutatec vid an airing... He he
flak monkey
posted on 22/6/09 at 07:42 PM Reply With Quote
Lol, doesnt seem like he was accelerating/trying and the pinto was There's no way it would be that much faster.
At the end of the day, maths/physics wins out, especially in the corners. Duratec is close to 40kg lighter overall than a pinto, plus has more power in standard form with throttle bodies than even a heavily breathed on pinto.... Once you are into 200+bhp pinto territory the money will get you a home brew supercharged duratec install and you'll see over 300bhp.
Sera
Andy D
posted on 22/6/09 at 07:52 PM Reply With Quote
Believe me, he was trying! The black car was a standard duratec on throttle bodies, my Pinto powered car has very similar power.
Dont think the weight comes into the equation over a certain speed, it's probably more about aerodynamics. (Brick like!)
flak monkey
posted on 22/6/09 at 07:54 PM Reply With Quote
It'll be interesting to see the difference after all my efforts to change the engine then. Had better not be slower!
Sera
Andy D
posted on 22/6/09 at 08:13 PM Reply With Quote
No, I'm sure it wont be......will it....
Cant quite put my finger on it, but a lot of 16v engined cars I find, just seem to rev for England. Sure the power figures are there, but there's a lack of "shove"
Try this vid
Pinto V 16valvers
I dont think there are two cars with the same engine there. There's 2lt Zetec, Honda S2000, Duratec, Busa, and VX . Pinto doesn't disgrace itself does it.
posted on 22/6/09 at 08:17 PM Reply With Quote
Nice videos but they don't really add much useful information when there are so many other variables which aren't compensated for (car set-up, tyres, driver skill / knowledge of track etc etc etc etc)....
flak monkey
My pinto suprises an awful lot of people too, there are a lot of misconceptions about them, but they are incredibly good, solid, reliable engines even when really pushed.
The problem with 16v engines is that they produce all their power and torque right at the top of the rev range, where as the pinto is very torquey right from 3000rpm upwards.
Sera
Andy D
posted on 22/6/09 at 08:39 PM Reply With Quote
True, for what it's worth we were all on the same tyres.. Driver capabilities variable. It was the straight line performance I was on about really... none of the other cars exactly belt away down the straights.
posted on 22/6/09 at 08:41 PM Reply With Quote
And the other way is a 99p zetec off ebay....
posted on 22/6/09 at 08:48 PM Reply With Quote
Hmm my ST170 twink has (according the Ford brochure) 170bhp & 195Nm from 2500rpm.
Has tons of load down torque and really howls when the vvt kicks in... only problem I find is it runs out of gears... maybe a new diff is required
mcerd1
posted on 22/6/09 at 08:54 PM Reply With Quote
you could get cossie rod's and pistons (if you can find std pistons that will give you the right CR)
or the accralite forged pistons have floating pins and fit strait on the cossie rods and you get a choice of compression heights too: linky
but they won't deal direct, you have to go through burtons
linky 2
linky 3
but none of these are a cheap option !
(£500 - £600 for 4 pistons new )
also remember that cossie rods are 0.060" (1.524mm) longer than pinto ones
and the cossie rods don't have oil spray jets like the pinto ones, so your best bet is to get a cossie 2wd oil pump and pickup pipe (which has the spray jets)
I got a set of s/h cossie rods from ebay for £60 and luckly they were all ok
Then I got accralite pistons (93mm pinto ones with 41.65mm comp. height)
then paid £80 to have them shortened to be flush with the top of the block an re-balanced (I'm going for ~11:1 CR for a NA build)
<<< see my avitar
then ended up having to buy a new oil pump and pickup pipe because I couldn't find a s/h one (£200 from GGR)
if you can find all the bits cheap enough I'd go for it, but its too easy to end up spending alot of money......
[Edited on 22/6/09 by mcerd1]
jpindy3
posted on 22/6/09 at 10:24 PM Reply With Quote
linky 2
linky 3
<<< see my avitar
yer thats what i have just got a new set of 2wd cossie pistons &rods the pistons are new got them alot cheaper than what berton sell tham at and the rods are second hand from a cossie garage,
pistons i got for 250 a set,rods 120 a set
oh the piston come with rings
a guy i know off of turbosport from sweden recons with a good turbo you can get over 300bhp,with the turbo i have witch is a t3 up to 240 depending on set up,
i know this is starting to sound like pub talk now,but i really do think the old pinto has good power to give when turboed,i have done quite a bit of resurch into it and you will be quite suprised at what its capable of.
mcerd1
posted on 23/6/09 at 11:39 AM Reply With Quote
what are you planning to do about the lack of the oil spray jets ?
I went for the easy option and used the cossie 2wd setup, not cheap new, but if you can find a S/H pump to get the special cover plate bit then its alot cheaper - as most recon / uprated pumps don't come with the plate that feeds the spray bar and thats the expencive bit !
you can see it on this new pump: Linky
or on my engine:
the 4x4 cossies had a different setup (that I've never had a good look at one)
-Robert
jpindy3
posted on 7/7/09 at 09:18 PM Reply With Quote
or on my engine:
-Robert
hi i managed to get a pump off ebay for 50quid,its a 4x4 one with the spray bar,i moded the pick up today,but it might have a clearnce problem,il take some pics
mcerd1
posted on 8/7/09 at 08:16 AM Reply With Quote
I'd like to see that - I've never seen any decent pics of the 4x4 setup
