Author: Subject: Zetec- Type 9
Numb nuts
posted on 23/6/09 at 06:31 PM Reply With Quote
Zetec- Type 9
Hi all
I am putting a 2.0l zetec onto type 9 box, just aquired a lightened flywheel without a spigot bearing.
Is the bearing a ford item and does anyone know the part number please
eddie99
posted on 23/6/09 at 06:33 PM Reply With Quote
Contact Raceline, they sorted me out for not much money
UncleFista
posted on 23/6/09 at 06:36 PM Reply With Quote
The Ford part number is FINIS code 1554973
Or eBay
Tony Bond / UncleFista
Numb nuts
posted on 23/6/09 at 06:45 PM Reply With Quote
Thanks for that now sorted one ordered via fleabay
miikae
posted on 23/6/09 at 06:55 PM Reply With Quote
I'v been told that when a friend fitted a Zetec to type 9 , the spigot bearing to use is a 21mm x 15mm F-33126 Z , Burton part no- FP347 ,( as from my records this is also used on the 2.0l Pinto engines)
Mike
If it can be done it i will be done .
posted on 24/6/09 at 07:23 AM Reply With Quote
I smell a rat.. flywheel without spigot bearing?
May be obvious but the spigot bearing is in the crank and not affected by the flywheel...
(taking cover!)
