m8kwr
| posted on 27/6/09 at 06:56 PM |
ZZR1100 Front Sprocket - Loose
I have just brought a new front sprocket for the engine i picked up about a week ago.
The sprocket is loose when I tighten the bolt up, moves a millimetre or so - i am assuming there should be no play.
When i put the sprocket onto the spindle you can still see the spindle, if you get what i mean, unsure if there is something i am missing either side
of it.
Many thanks
eznfrank
| posted on 27/6/09 at 06:58 PM |
Probably missing a locking tab washer thingymajig
Guinness
| posted on 27/6/09 at 09:08 PM |
My sprocket adaptor was loose too. Fitted two lock washers and that sorted it.
They look like this:-
And you sort of bend them back around the nut.
HTH
Mike
m8kwr
| posted on 28/6/09 at 07:50 AM |
eznfrank/Mike - Many thanks - just need to try and find one now.
Guinness
| posted on 28/6/09 at 08:30 AM |
No problem.
I got mine from the local Kwak dealer, were only a few quid and cheaper than the internet, by the time I had added the dreaded P&P!
Mike
