Nash
| posted on 27/6/09 at 09:40 PM |
Shortened Sump Dipstick!
Sorry not being rude! My question is what do you use for a dipstick in a shortened sump x-flow?
Regards.......Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
Bigheppy
| posted on 27/6/09 at 09:45 PM |
A crossflow dipstick shortened the same amount as the sump.
Nash
| posted on 27/6/09 at 09:53 PM |
But if I cut a bit out of the middle I lose the max / min markings cos the end falls off ???
| posted on 27/6/09 at 10:17 PM |
If possible do not shorten the dipstick, you want to keep the same oil level in the sump.
James
| posted on 27/6/09 at 10:18 PM |
Agreed!
- Muhammad Ali
iscmatt
| posted on 27/6/09 at 10:29 PM |
Agreed!
+1
My sum is also shortened but no capacity is lost by adding extra capacity to the front of the sump, some do it to the side, therefore the oil level is
the same
Nash
| posted on 27/6/09 at 10:30 PM |
This may be a silly question then but does that mean I run the level "high" on the standard dipstick?
Chippy
| posted on 27/6/09 at 10:50 PM |
I think that if you put the dip stick in, you will find that it goes in just as far as it did originaly. Usually shortening the sump has no effect on
the dip stick, as it's already shorter than the OEM sump. Cheers Ray
snapper
| posted on 28/6/09 at 07:38 AM |
To clarify, when you shorten the sump you effectively move the bottom up, most add capacity to the side.
The top level of the oil does not change.
The top level/full mark on the dipstick is there to stop you filling up with to much oil causing the crank to splash into the oil.
I eat to survive
I drink to forget
Nash
| posted on 28/6/09 at 08:32 AM |
Thanks All. As you will have guessed I didn't shorten the sump the guy I bought it from did and currently it doesn't have a dipstick in
it. (No jokes please its tooooo obvious
Regards........Neil
