RK
| posted on 28/6/09 at 01:32 AM |
oil temp sensor ca18det?
Anyone know where this is on the engine?
Also speedo, and voltmeter. Where do these go? There are wires coming out of the transmission that have two pins (two of these sets, one further in
front than the other). The speedo has 3. No idea whatsoever for the volts.
I have hooked the tacho to the ground on one of the coils. Don't know if it works yet.
Thanks!!
RK
| posted on 24/9/11 at 01:21 AM |
It is right next to the oil filter. This is just for the low pressure idiot light, not for a gauge.
Tach: I used the ECU wire to a DigiDash2
Speedo: I used the DigiDash2 sensor and magnets to the propshaft.
