Author: Subject: Oil filter catalogue listing threads and diameter of sealing ring?
alistairolsen
posted on 29/6/09 at 07:07 AM Reply With Quote
I need to find a catalogue of oil filters that lists each by its spin on thread and the diameter of the sealing ring.
I am trying to find out if there is a shorter filter available which would fit a volvo T5 filter head. I know going smaller is bad in theory but if I change it regularly (every 2 or whatever) it should be fine.
Even a gain of 10mm would be worth having
[Edited on 29/6/09 by alistairolsen]
richardlee237
posted on 29/6/09 at 07:25 AM Reply With Quote
Give this one a go
http://www.wixfilters.com/filterlookup/racing.asp
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
alistairolsen
posted on 29/6/09 at 07:48 AM Reply With Quote
ok, quick search by vehicle gave me this:
zoom
Part Number: 51311
UPC Number: 765809513112
Principal Application: Volvo (92-99), Kubota, New Holland, Volvo Trks + Buses, Mahindra Tractors
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.372
Outer Diameter Top: 3.661
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=8/21
Burst Pressure-PSI: 331
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
I cant find a way to list filters like youd get in for instance a clutch catalogue tho. Going to be a long day searching thru all the filter part numbers one by one!
alistairolsen
posted on 29/6/09 at 08:08 AM Reply With Quote
ok, found the Australian company Ryco who let me search by seal diameter and thread.
http://www.rycofilters.com.au/catalogue/dimension
only one was shorter than the standard T5 filter (85.6mm) which was Z314 at 62mm
Rtcos site was then a little useless, but going back tot he Wix site I coul cross reference that number with the equivalent Wix filter and then look up applications which gave me Renault (68-84) and lotus europa (Part number 51335)
Part Number: 51335
UPC Number: 765809513358
Principal Application: Renault (68-84)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.483
Outer Diameter: 3.670
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Burst Pressure-PSI: 280
Gasket Diameters
15614 2.834 2.462 0.255
Should allow me to remove an extra inch off the sump and drop the engine by the same.
The only possible issue is the by pass valve pressure on the renault filter is the bypass pressure is only around half what the T5 filter is. I assume this will only become an issue as it gets clogged? (needs to be changed sooner)
richardlee237
posted on 29/6/09 at 11:51 AM Reply With Quote
The relief valve pressure could be a bit of a problem. it could well be that the Volvo system pressure is a bit higher than the Renault so that the filter will by- pass after a very few running hours.
It should be possible to fit a dummy filter head and pipes to give you a remote screw on filter ?
Richard
If you speak to one of the big after market suppliers like Baldwin filters in the States they may be able to guide you.
Baldwins are mainly industrial engine filter suppliers but worth a go.
http://www.baldwinfilter.com/[/email]
Quote Lord Kelvin
Quote Richard Lee
"and cars"
