MautoK
| posted on 1/7/09 at 03:47 PM |
Blanking plugs on Pinto block
L&G,
Low down at the rear offside of the Pinto block there are two blanking plugs. They are just under 18mm AF.
  Blanking plugs
What are they for? I'm thinking oil cooler, but they're at the opposite corner from the pump.
If they aren't for a cooler, how do you plumb one in? I hope not one of those filter sandwich plate things with take-offs!
John.
DRC INDY 7
| posted on 1/7/09 at 04:09 PM |
The big one or the top arrow is the water jacket drain plug
The bottom plug bottom arrow is oil return from the turbo
Puddle Dodgers Club
| posted on 1/7/09 at 04:11 PM |
IIRC they're just there to blank off holes in the block although why not use core plugs I'm not sure - maybe coolant drain holes.
Oil coolers are typically done with a sandwich plate take between block and filter.
MautoK
| posted on 1/7/09 at 04:13 PM |
Thanks, guys.
DRC INDY 7
| posted on 1/7/09 at 08:28 PM |
why do you feel the need to fit a oil cooler
Puddle Dodgers Club
