jpindy3
| posted on 4/7/09 at 08:35 PM |
cossie info oil pumps
can you use a 4x4 oil pump in a 2wd engine,i think yes as the blocks pritty much the same,but i ant sure?
r1_pete
| posted on 4/7/09 at 09:04 PM |
Can't see the pumps being different, the pick up pipe maybe as the sumps are different.
Chippy
| posted on 4/7/09 at 10:36 PM |
From memory when I did mine the oil pump is exactly the same on both models, and I am pretty sure that the pick up pipe is to. HTH Ray
jpindy3
| posted on 5/7/09 at 08:05 AM |
the thing is thay look a little diffrent but i think the fixing holes are in the same place,im going to take a chance on it
