Jasongray5
| posted on 8/7/09 at 09:00 PM |
Spigot bearing help?
I was wondering if there was a tutorial avaidable for changing a spigot bearing in a zetec anywhere?
Or if anyone had any tips/advice?
Going to give it a shot tomorow morning if my engine hoist (read tractor) will start.
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
| posted on 8/7/09 at 09:08 PM |
You don't need a tractor to pull it out, just a nice snug piece of rod, some grease and a hammer..
Jasongray5
| posted on 8/7/09 at 09:13 PM |
LOL! Its just to lift the engine up off the ground. Snug peice of rod what now?
How hard can it be?
Jasongray5
| posted on 8/7/09 at 09:46 PM |
No worries guys, just discovered why i couldnt find it in a search, i was searching for a USER called "spigot bearing removal"
29 hours of work done, only 9 remain...
How hard can it be?
MautoK
| posted on 8/7/09 at 10:25 PM |
If the Zetec spigot brg is anything like the Pinto you'll need a Dremel. (found out the hard way!)
I tried the hydraulic method and it didn't budge
mad4x4
| posted on 9/7/09 at 06:56 AM |
YOu should be able to remove it with hydraulics, your rod was aboviously not snug enough
Scot's do it better in Kilts.
| posted on 9/7/09 at 07:58 AM |
how can the rod be snug enough - unless it has cut outs for the needle rollers.
I tried this and all that happened was I got the drift stuck in the bearing, that for a moment or nine looked like I was not gonna get out -
search my post.
I used a dremel grinding stone to cut through the race enough to weaken it and then collapse it with a chisel.
| posted on 9/7/09 at 07:44 PM |
If your Zetec is fresh out of a donor car then it probably won't have a spigot bearing fitted, easy to fit a new one.
NS Dev
| posted on 9/7/09 at 08:56 PM |
thay have always "hydraulic-ed" out for me, but you do have to "surprise" the rod with a very big hammer hit very hard!
ss1turbo
| posted on 10/7/09 at 10:14 PM |
You do tend to have to be rather brutal with it...I usually end up not bothering with the hydraulic method and resort to sheer violence (chisel)...
I read somewhere that only the ST170 Zetec has a spigot bearing as standard??
Long live RWD...
