Author: Subject: Which Accelerator Cable
VinceGledhill
posted on 15/3/04 at 09:09 AM Reply With Quote
Hi People.
I'm just gettin my pedals together and have noticed that the accelerator cable is too short by a mile.
I am using a Pinto and twin webbers and an MK pedal set.
Any ideas which cable will fit? It needs to be a long one because it is going from low right at the pedal end, to top left of the engine bay.
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
bob
posted on 15/3/04 at 07:35 PM Reply With Quote
vince
I needed a longer cable for my twin choke weber,i found a sierra cable fitted nice.
There are two sierra cable available the one i used has the Weber conections at carb end so you may be able to use it.
My part number was FKA 1018 also on the bag was QTC 4048 if that helps,sorry no make on bag.
I know i've got different carb set up but its worth checking.
VinceGledhill
posted on 16/3/04 at 09:57 AM Reply With Quote
Thanks for that Bob. I've got the one from the Sierra donor???? this is the one that is miles too short.
Regards
Vince Gledhill
bob
posted on 16/3/04 at 06:52 PM Reply With Quote
There's two types for the sierra,one is only about 400mm long and the other is about 1.2m.
