Author: Subject: Pinto timimg belt change
madrallysport
posted on 18/7/09 at 09:33 AM Reply With Quote
I'm looking to change the timimg belt today on my pinto engine, any one got any instructions on how to do it, i have a fair idea but i just want to read over some thing and make sure i have every thing pinned and in the correct postions. Cheers Davy
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
RichardK
posted on 18/7/09 at 12:02 PM Reply With Quote
I've heard of people cutting the old one down the length with the plugs removed so it turns over easy and then taking off the front half of the old one,then sliding the new one on then cutting the old one totally off and pushing the new one fully home. I'd try that but just in case I would mark up where all the pulleys are at the mo before taking the old one off. Just an idea.
Cheers Rich
Gallery updated 11/01/2011
posted on 18/7/09 at 01:57 PM Reply With Quote
Slacken the pulley bolt (tight) Turn the crank so that it is at TDC and the cam mark is aligned, mark the distributor shaft gear position , slacken the adjuster and remove the belt. Refit reversing procedure. Worse part is likely to be getting the pulley undone/off
jpindy3
posted on 18/7/09 at 04:45 PM Reply With Quote
ha thats a good idea rich
