Author: Subject: RV8 inlet manifold
Paul (Notts)
posted on 23/7/09 at 07:44 PM Reply With Quote
RV8 inlet manifold
would this manifold fit on a 3.5 rv8 block ?
I could then use megasquirt to run it?
Paul
link
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230357639676&fromMakeTrack=true&ssPageName=VIP:Watchlink:middle:uk
[Edited on 23/7/09 by Paul (Notts)]
Snuggs
posted on 23/7/09 at 08:11 PM Reply With Quote
Paul,
have a look at Rimmer Bros online catalog for the series II disco.
Looks very similar to me.
The one on ebay should be very easy to fit and run MS.
Sounds like a bargain.
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
DanP
posted on 23/7/09 at 09:01 PM Reply With Quote
Hi Paul,
I'm pretty certain all RV8 inlet manifolds are interchangeable, if you look at aftermarket ones like the edelbrock or JWR they make no reference to only fitting certain blocks.
Dan
mark chandler
posted on 23/7/09 at 09:51 PM Reply With Quote
Yes, no problem fitting this to the heads but they are not as good for max power as the old ones, not sure if you will still be able to run a distributor though.
Does look expensive to me.
[Edited on 23/7/09 by mark chandler]
Agriv8
posted on 24/7/09 at 07:19 AM Reply With Quote
I thinks thats refered to as the thors system They are quite tall IIrc.
Look for a traditional ( 3.9 or above ) RR one, I may have one in the garage surplus to requirements.
Regards
Agriv8
ss1turbo
posted on 24/7/09 at 06:51 PM Reply With Quote
Yep - thats a Thor manifold. For some side by side comparisons, have a look here..
http://spagweb.com/v8mini/gallery/05/01_efi_compare/
Long live RWD...
