Author: Subject: Zetec 1.8 silvertop torque settings
lotusmadandy
posted on 25/7/09 at 10:16 AM Reply With Quote
Hi all,
I am after the torque settings for the big ends and windage tray.
I borrowed a disk from coozer but my
computers wont open it.
thanks guys
prelude1980
posted on 25/7/09 at 10:24 AM Reply With Quote
i got the oil baffle tightened to 19 Nm
Big end caps to 18 Nm then a further 90 degrees
Main bearing cap bolts & nuts to 80 Nm
Taken from the haynes manual
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
lotusmadandy
posted on 25/7/09 at 10:33 AM Reply With Quote
I am much obliged to you.
By the way is it ok to reuse the big end bolts?
Danozeman
posted on 25/7/09 at 11:19 AM Reply With Quote
The big end bolts on a zetec are the weekest point. I wouldnt personally.
Dan
big_wasa
posted on 25/7/09 at 11:27 AM Reply With Quote
Big end bolts are stretch bolts and are torque to yeild and should be replaced each time unless they are ARP bolts that can be re used.
Main cap bolts can be re used.
[Edited on 25/7/09 by big_wasa]
