RMarine
| posted on 1/8/09 at 07:34 PM |
1.8 Zetec to type 9 gearbox
Hi all, i now have my zetec engine. i also have a 5speed type 9 gearbox and bellhousing... What do i need to do with the flywheel and clutch (what
type?), bearings (what type?), and starter motor(again what type?) and i'm i forgeting anything...???
chris-p-duck
| posted on 1/8/09 at 07:45 PM |
I used a combo for my clutch with the pressure plate from the Zetec and the friction plate from a CVH. You need a spigot bearing (Burton Power) and a
new release bearing from a Capri (QH no. CCT133) and a CVH starter motor.
With those bits it should go together ok.
Chris
austin man
| posted on 1/8/09 at 08:07 PM |
Im running a 1.8 currently and using the zetec friction plate and pressure plate along with the sierra thrust bearing and arm. No problems to date
done 6,000 miles you do need the spiggot bearing.
RMarine
| posted on 1/8/09 at 08:14 PM |
Would this one do?
Link to ebay
ss1turbo
| posted on 1/8/09 at 08:46 PM |
That looks like the chap...
Long live RWD...
RMarine
| posted on 1/8/09 at 08:55 PM |
what cvh starting motor?
chris-p-duck
| posted on 1/8/09 at 09:06 PM |
Mine came from a 1.8 cvh from a sierra.
You can use a pinto one but i think some spacers are needed. Not sure of the details on that though......
Chris
ss1turbo
| posted on 2/8/09 at 07:16 AM |
...or a DOHC (2.0 Twin Cam) Sierra one
Long live RWD...
lotusmadandy
| posted on 2/8/09 at 04:53 PM |
If you use a pinto starter you need
a 14mm spacer between the starter and bell housing.
