Author: Subject: loose prop adapter
mookaloid
posted on 7/8/09 at 07:23 PM Reply With Quote
loose prop adapter
just swapping my engine sprocket for the prop adapter, and it won't quite tighten up - i.e. the adapter is still slightly loose even though the centre bolt is tight.
It seems that the shaft is slightly longer than the depth of the adapter.
I can either shim it, which is my preferred solution or perhaps i should just take a few thou off the end of the shaft with Mr angry grinder or should I just fit it as it is? does it really matter - the original sprocket seemed to be not tight just the same.
What has everyone else done?
Mark
blakep82
posted on 7/8/09 at 07:28 PM Reply With Quote
i'd vote shim
________________________
RichardK
posted on 7/8/09 at 07:30 PM Reply With Quote
Yep, shim, don't like things sloppy
R
Gallery updated 11/01/2011
mookaloid
Forgot to ask - if shim is the way to go, where would I get a suitable shim?
mookaloid
posted on 7/8/09 at 07:31 PM Reply With Quote
R
And what's wrong with sloppy things? I have always been happy to put up with sloppy seconds......
I'll get my coat.......
flak monkey
posted on 7/8/09 at 07:41 PM Reply With Quote
How thick does it need to be? And what sort of size?
Sera
http://www.motosera.com
LBMEFM
posted on 7/8/09 at 07:49 PM Reply With Quote
Mine was the same, I put a shim in and it's fine. Barry
blakep82
posted on 7/8/09 at 07:53 PM Reply With Quote
washers?
mookaloid
posted on 7/8/09 at 07:55 PM Reply With Quote
I.D 31mm O.D. 38mm and about 0.5mm thick should do it - maybe 0.75mm better too thick than too thin!
beer token on offer to a good man who can make one for me
Do you know anyone David?
Mark
flak monkey
posted on 7/8/09 at 07:58 PM Reply With Quote
Hi Mark,
I'll have a look and see what materials I have in stock tomorrow. Defo have some ali, but would be better in steel.
Sera
mookaloid
posted on 7/8/09 at 08:00 PM Reply With Quote
I'd be happier with steel too.
Andy B
posted on 7/8/09 at 08:12 PM Reply With Quote
Just a quick point
there should be a slight end float when the bolt and washer is tight. That is to say that the bolt should tighten down onto the gearbox output shaft and not the adaptor.
If you look at any bikes sprocket you will find this small tolerance.
The reason for this is that if the washer hits the adaptor and then the bolt continues to tighten there is a tendency for the washer to dish slightly. The thrust and backlash in the dog box then works the washer and slowly undoes the bolt.
We found this with the rgb cars which were forever undoing the main adaptor bolt until we allowed some tolerance.
Hope that helps
regards
mookaloid
posted on 7/8/09 at 08:38 PM Reply With Quote
Originally posted by Andy B
Just a quick point
Hope that helps
regards
Ah that makes sense thanks Andy. I'll just fit it as it is then
Mark
Mark G
posted on 7/8/09 at 10:19 PM Reply With Quote
makes me feel better about my sloppy adaptor now!
RichardK
posted on 7/8/09 at 11:06 PM Reply With Quote
Slight end float and sloppy are two different things aren't they? If its sloppy I would still pack out to attain slight end float.
If it doesn't seem right....
R
