gregf27
| posted on 9/8/09 at 02:38 PM |
type 9 gearbox - difficult to change gear
Been out watching the Hill climbing at Loton park today - great fun!!
on the way back home , after stopping for some more fuel, when I pulled out from the garage, getting it into gear was really difficult, managed it in
the end, but summat aint right.
do you think the clutch cable may have stretched a bit , and need tightening???
makes quite a "clunk" when you put it into reverse too.
other than that the "running in" of the red top engine is doing REALLY well!!!
Pinto to Redtop - well worth it!!!!!!!
Mark Allanson
| posted on 9/8/09 at 03:42 PM |
Clutch adjustment - easy fix
tomgregory2000
| posted on 9/8/09 at 03:56 PM |
do you have an handle extension fitted?
| posted on 9/8/09 at 04:19 PM |
Incorrect gear oil in a type 9 will cause similar problems as will dragging/incorrectly adjusted clutch. Another possible culprit is the spigot
bearing .
lotusmadandy
| posted on 9/8/09 at 04:25 PM |
I had the exact same problem with
my type 9 a few weeks ago.Turned out
the adjuster lock nuts had come loose and wound off.
gregf27
| posted on 9/8/09 at 10:19 PM |
cheers everyone -
same as Andy's - lock nut had worked loose, all set up again now - quick fix!!
makes a change!!
Greg
