Author: Subject: Type 9 / clutch / arm identification Q
MautoK
posted on 12/8/09 at 02:03 PM Reply With Quote
L&G,
I posted a 'wanted' for a clutch release arm and associated bits & pieces, but it seems it's not quite that simple (never is! )
Is my requirement better identified given the following:
Bellhousing: '71BB 7505' and 'AC' on the rear face offside and what looks like '13B 4' and 'D' on the starter bulge. It measures 6 15/16" from front to back machined faces.
Clutch plate: 8.5" OD, 6" ID, 23 spline; marked 'LC 04DM' and '00 8A' on the gearbox side, '57691' on f/w side.
Pressure plate: 18 fingers; marked '4 120 047 01' on one finger.
Input shaft: 8 15/16" long.
Release bearing guide sleeve: 4" long overall; cylindrical front projection (upon which the release brg slides) is 2 13/16" long, shade over 1 5/16" OD, 1 1/16" ID. Marked '839T-7050-AA', '17510' and '2'
Gearbox case: marked '839T-7006' on offside, '4J20A2' and '1F8' on nearside; stamped '2B' and '2' on inside top offside.
G/box tag: 'R839T/KD'
I'm hoping to identify which species of release arm and release bearing I should be looking for.
Any advice gratefully received!
John.
snapper
posted on 12/8/09 at 05:21 PM Reply With Quote
Previous thread with photos.
Standard bell housings will take the standard clutch lever, the Capri and Escort variants were on the 4 speed box
Clutch lever thread
I eat to survive
I drink to forget
MautoK
posted on 13/8/09 at 01:29 PM Reply With Quote
Thanks, Snapper. I'd not seen that thread before.
