MakeEverything
| posted on 19/8/09 at 03:01 PM |
Broken Drive Bearing
erm, Oops!
This is why i didnt have any drive on the way to the MOT!
  Broken 1
I found this inside the rear O/S Drive hub (Mid Engine Car with Transaxle)
Anyone know where to get a replacement off hand?
Kindest Regards,
Richard.
blakep82
| posted on 19/8/09 at 03:14 PM |
does simplybearings.co.uk (?) have anything? see if you can find the numbers off the side of the bearing and search on there
________________________
MakeEverything
| posted on 19/8/09 at 03:21 PM |
Its the cage i need (salvaged the bearings), but i cant buy the cage without the CV joint!
Kindest Regards,
Richard.
Bluemoon
| posted on 19/8/09 at 03:27 PM |
I'd probably replace the joint completely.. Also something amiss for it to breakup like that...
Dan
MakeEverything
| posted on 19/8/09 at 03:39 PM |
I think it was already broken. This was the first drive out in it for me.
Anyone got a spare CV joint?
Ford Part #: 72CG-4635-BA
Anyone know what this is off?
Kindest Regards,
Richard.
RickRick
| posted on 19/8/09 at 03:41 PM |
if it's a sierra one then i might have something of use to you, i've changed a cv joint thinking it was the cause of my knocking
problems, but it didn't solve it. it's now in bits, any good to you?
MakeEverything
They look like these:
Kindest Regards,
Richard.
mangogrooveworkshop
| posted on 19/8/09 at 04:27 PM |
mmmm think i may need some
mcerd1
| posted on 19/8/09 at 07:09 PM |
just the normal sierra ones ? (i.e. 100mm lobro's not the cossie 108mm ones)
I've got a couple of old CV's left off a 101,000 mile granada if you need one (same joints as the sierra)
I got recon CV's for my dax from the local motorfactors (Pentland), £25+VAT each (but they couldn't do exchange ones, I got my old ones
back - or so they tell me)
[Edited on 19/8/09 by mcerd1]
