Author: Subject: Clutch slave cylinder remote bleed
flak monkey
posted on 19/8/09 at 07:06 PM Reply With Quote
I need to make a spacer for my clutch slave cylinder as its too shot otherwise.
This means that the feed and bleed hoses dont line up with the holes in the bell housing. The feed line will be flexi anyway, so that doesnt matter in the slightest.
However the bleed is the std M8 type and normally has a long bleed nipple fitted which sticks out the top of the bellhousing. Obviously this is where the problems start.
I ideally need to make up a flexi bleed line, but does anyone know if the appropriate end fittings are available? I.e an M8 male fitting, and a remote bleed nipple to fit on the other end?
I could cobble something together with some modded fittings and a few home made bits, but I would rather not if the right stuff is available...
[Edited on 19/8/09 by flak monkey]
Sera
http://www.motosera.com
flak monkey
posted on 19/8/09 at 07:28 PM Reply With Quote
Sorted the bleed end, bleed nipples are available in M10x1 to fit into a female conave seat hose end.
The only other thing to find out is if M8x1.25 male ends are available for -3 hose for the cylinder end.
Sera
