Author: Subject: fuel pump on busa problem !
P ?
posted on 19/8/09 at 08:05 PM Reply With Quote
hi all
got myself a hayabusa 00/01 engine kit and was going to start playing with the shortened baffled sump when i noticed the fuel pump on the fuel rail....
i know i need a new fuel pump that can be mounted to the inside of my alloy fuel tank but was just wondering weather im o.k with simply just swapping from one type to another without any problems in installation to my car or compatibilty to the engine ?
also anyone know where i can get a decent price on a fuel pump as i just got a quote for £310 main dlealers :s
cheers all
P.s why is it when you start to make headway something else trips you up :s
yorkshire-engines
posted on 19/8/09 at 09:07 PM Reply With Quote
Hi you have 2 options
use the standard pump on the rail it will work ok with no problems and just have a feed and return pipe on the tank
but i know MK well and they use a in tank pump more often than a rail pump
so i can get you a busa in tank pump for around £70 and you just need 1 feed pipe to your injectors
cheers malc
P ?
posted on 19/8/09 at 09:16 PM Reply With Quote
cheers for the input £70 sounds reasonable
