FASTdan
| posted on 27/8/09 at 11:49 AM |
megajolt on biked carb'd duratec
Just reading up on megajolt and I see you have the option to run a TPS controlled system or vacuum (MAP) controlled.
Is there any benefit (other than practicalities of building incorporating either) to one over the other?
We've got ZX9R carbs, do they come with TPS?
If we have no TPS then I'd probably sway toward MAP as I'm making the manifold anyway so it would be no great hardship to include a
take-off in each header.
I'd have thought MAP would be better anyway?
On another note, are the EDIS modules pretty robust - ie is a 2nd hand one going to be reliable or are they prone to failure? In which case shelling
out for a new item would be the way to go?
omega0684
| posted on 27/8/09 at 12:01 PM |
do carbs have vac pipes to run a map sensor from? (My R1 Carbs Didn't)
FASTdan
| posted on 27/8/09 at 12:28 PM |
Probably not but I'd be taking it off the manifold headers anyway, into a collector and then to the MAP input of the MJ.
| posted on 27/8/09 at 12:55 PM |
Older ZX9 carbs don't have them but newer ones do. Don't know the year it change btw.
New TB's tend to have both...
mcerd1
| posted on 27/8/09 at 03:28 PM |
most of the ZX9R carb's have a TPS
if you've got some pics of your carbs we should be able to tell you what you've got
you can use a MAP sensor with multiple carbs, but you could struggle to get a nice clean signal for the ECU, as inlet manifold/carb for each cylinder
is separate and therefore the pressure will ‘pulse’ – on a setup with a single carb the pressure in the manifold will average out between all the
cylinders
(I've been told that you'd need to run a vac pipes from each cylinder and join them together into a larger chamber, then connect that to
the MAP sensor to get it to settle down)
so basically a TPS setup should be easier
even if your carbs don’t have one you could always fit one like this linky (half way down
the page)
here's a pic of mine (late model ZX9R)
you can see the cable for the TPS hanging out the left side of the pics (3 wires)
the TPS itself is the little black plastic thing on the end of the spindle
[Edited on 27/8/09 by mcerd1]
FASTdan
| posted on 27/8/09 at 03:58 PM |
cylinders
the page)
Thanks mate, I'll get some pics up of our carbs. I must admit I dont recall seeing any electrical connections but I could be wrong as I havent
looked at them properly yet.
mcerd1
| posted on 27/8/09 at 07:32 PM |
working linky
