tilly819
posted on 29/8/09 at 12:03 PM |
Help Im having a Gear box Cyrsis
Hi all Im Having a very concerning crysis
Iv got the car up on the stands at the moment and have just been doing abit of testing and basicly when i let the clutch out to engage drive it really
nice comes up to the bite, wheels start turning etc etc then once the cluch is about halft the 3 quarteres out i get a horrible grinding, clunking
noise from the gear box,
Engine is a 2002 honda super blackbird.
Any ideas, i have a feeling its quite serious hoping its something to do with the clutch rather than the gear box itself, unfortunetly i now very
little about gear boxes.???
Thanks Tilly
| posted on 29/8/09 at 12:47 PM |
Drop the car to the ground and see if you still have the problem.
Phil
tilly819
| posted on 29/8/09 at 01:43 PM |
still there just driven it up and down the drive
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
Dangle_kt
| posted on 29/8/09 at 01:57 PM |
have you taken the clutch cover off for a looksee?
Locost tip - If you get the front of the car up on ramps, then you won't loose all the oil - or drop it first and recycle it through a strainer.
(or just use new oil...)
I think the blackbird is the same as most other bikes and has the clutch actuator built into the clutch case - check all is right there as a first
port of call.
Take the clutch plates out, check them all over
Same with the basket (might need a "special" tool to get certain lock washers off)
Check it all over and report back.
I think (though can;t gaurentee) that it will be the clutch - becuase if the gearbox was goosed it would always make a funny noise when it was under
load, not a certain point AFTER the bite point.
Have you done anything do it you havn't mentioned?
[Edited on 29/8/09 by Dangle_kt]
tilly819
| posted on 29/8/09 at 02:04 PM |
only thing i can think of is that i may have over traveled the clutch wilst setting it up but il put the front up and take the clutch to bits and see
whats what, hopefully nothing to expencive, il report back shortly, since i have the laptop in the garage with me tee hee
tilly
