Johneturbo
| posted on 30/8/09 at 02:11 PM |
another another diff Q
I've done a search on this and not really got a definite answer
I'm runing a 3.38 (push in shafts) diff but would like to try a 3.62 ratio, so then got thinkin of trying an lsd
now can i keep my push in shafts or do they have to be bolt on for lsd?
cheers
john
hobzy
| posted on 30/8/09 at 02:14 PM |
Don't know, but can I have first dibbs on your 3.38 please
daviep
| posted on 30/8/09 at 05:58 PM |
They need to be bolt on for an LSD but you can make hybrid driveshafts so you don't need to change your hub setup. At least thats what
I've read.
Davie
Gary 7
| posted on 30/8/09 at 08:00 PM |
Try a search on drum shaft theres a thread there on coverting a 2 litre drum shaft to work with an lsd .
http://www.locostbuilders.co.uk/viewthread.php?tid=93484
http://www.locostbuilders.co.uk/viewthread.php?tid=36943
[Edited on 30/8/09 by Gary 7]
Johneturbo
| posted on 30/8/09 at 10:02 PM |
Great lots of info there
Sounds like half the battle is getting all the right parts.
does anyone know how many splines there is on bolt on shafts at the hub end
i'm running disc brakes already with a drum to disc plate converter, so wonder if i'd also need to change the hubs to match if i just got
bolt on shafts shafts
Gary 7
| posted on 31/8/09 at 02:21 PM |
If you want to use bolt on shafts,you will need the complete shaft and bearings and hubs from a disc braked car to do it .The stub shaft and bearings
are a larger diameter,so you may need to change or modify the rear uprights to fit.
Johneturbo
| posted on 1/9/09 at 03:22 PM |
Yep thats what i thought, shame!
reading that link you posted. i had a spare set of push in drive shafts and took apart in inner tri pod, but had 32 spines which didn't make any
sense from what was posted in that thread! Hmmm
Gary 7
| posted on 1/9/09 at 04:13 PM |
I also cut open a joint cover on some 27mm shafts and found 32 splines ,shafts came from a 1.8 cvh sierra.They do exist in 25 spline just finding a
pair is the problem the loint cover i cut was half the length of a regular joint cover,so you need to find 27mm shafts with full length joint cover
to strike lucky i think.
Johneturbo
| posted on 1/9/09 at 04:47 PM |
Not sure what are on my car joint cover wise, but i'm not gona butcher them!
i need to find a cheap lsd first anyway
[Edited on 1/9/09 by Johneturbo]
