Author: Subject: very simple question about... bolts!
55ant
posted on 1/9/09 at 09:45 AM Reply With Quote
hi there guys, just got a K&N filter delivered for the Indy, small problem, no bolts. i need the four bolts to attatch it to the dgas carb i have running, does anyone know the size of bolt i need?
also anyone have a link about cutting a hole in the bonnet! im thinking dremmel??
thanks everyone, trying to get as much done on my day of before the rain!
r1_pete
posted on 1/9/09 at 09:51 AM Reply With Quote
They are M5, pitch is 0.8 which is standard and most suppliers will assume that unless stated differently.
55ant
posted on 1/9/09 at 10:59 AM Reply With Quote
brilliant cheers,
posted on 1/9/09 at 12:42 PM Reply With Quote
how big a hole? what material is the bonnet and what thickness?
small hole you can drill and then file out to size - for GRP and metal (steel/aluminium).
larger hole for say an air filter or two, I'd recommend this (aluminium or steel).
<--- linky
eek - nearly £ 60 - a lot I know but does a great job,. one of the few items from MM that I have bought, I guess it is because it is not one of thier clarke own brand items.
[Edited on 1/9/09 by 02GF74]
Macbeast
posted on 1/9/09 at 02:52 PM Reply With Quote
Chain drilled, joined up with hacksaw blade then Dremmeled. I made the initial hole smaller than needed and placed the bonnet on so as to see how much I needed to open it up, used masking tape to draw the final shape.
