Author: Subject: Ford 2.8 v6 lumpy idle and part throttle
mikeb
posted on 3/9/09 at 11:08 AM Reply With Quote
Not a big issue but I can't seem to get my 2.8 v6 on K-jet to idle consitantly below about 1300. it will idle lower but seems a bit lumpy. Also when cruising with virtually no throttle is feels lumpy also, lumpy or slightly missing every now and again I'm unsure but it is noticeable.
As soon as I open her up there is no hesitation just a good wollop of torque
I haven't changed the plugs or leads since the rebuild. Finally MOT'd her last week
Any thoughts, I did wonder whether anyone slipped a high lift cam in at a previoius point in her life (here's hoping)
Mike
[Edited on 3/9/09 by mikeb]
Mr Whippy
posted on 3/9/09 at 11:34 AM Reply With Quote
A lumpy idle on an older engine is sometimes due to a worn cam too. Its best to change out the original plastic toothed timing cog btw as they have a habit of stripping. Burton can supply an all metal one.
posted on 3/9/09 at 12:10 PM Reply With Quote
Do a compression check; a cylinder low on compression can drop out at low engine speeds and loads.
Mr Whippy, I though the fibre timing gear was only a problem on the old Essex engine?
[Edited on 3/9/09 by MikeRJ]
Mr Whippy
posted on 3/9/09 at 12:27 PM Reply With Quote
I have the 2.8 v6 cologne too and that big cogs teeth are normally of brown plastic.
Quote from Burton -
The 2.3 and 2.8 are significantly different since they feature Siamese ported heads, fibre-teeth cam gear and shorter stroke. In contrast, the 2.9s cam is chain driven in the opposite direction and features 3 port heads.
You can also get the cogs here -
linky
They are not straight cut so are not too loud
[Edited on 3/9/09 by Mr Whippy]
posted on 3/9/09 at 02:20 PM Reply With Quote
if it is a flap air flow meter it is not unknown for the pivot of the flap to stick
posted on 3/9/09 at 03:52 PM Reply With Quote
I've learned something new then! Surprised they stuck with this idea after the rather weak Essex design.
posted on 3/9/09 at 04:00 PM Reply With Quote
Last Colonge 2.8 engines used nylon like plastic timing wheels rather than fibre
stevec
posted on 3/9/09 at 04:08 PM Reply With Quote
They are also known for inlet manifold gasket creep and leakage.
