RMarine
| posted on 11/9/09 at 09:36 PM |
Just checking
i have just fitted my engine, and found that my engine is off level and maybe a bit low. what do you guy's think???
please see photos below...
RMarine
| posted on 11/9/09 at 09:37 PM |
and this one
RMarine
| posted on 11/9/09 at 09:38 PM |
and this
PAUL FISHER
| posted on 11/9/09 at 09:43 PM |
Looks a bit low to me,sump to ground clearance needs to be around 100mm
Miks15
| posted on 11/9/09 at 09:55 PM |
if ur worried, add about a inch to your engine mounts and leave te gearbox mounts alone, that will raise the front and level itout, and aso icrease ur
ground clearance, mabye add a little extra to ur O/S mount to level it the otherway
iscmatt
| posted on 11/9/09 at 10:19 PM |
As above, just make sure that you can still get the bonnet on! Or you could add a scoop for more clearance??
EDIT - Spelling!!
[Edited on 11/9/09 by iscmatt]
smart51
| posted on 12/9/09 at 06:15 AM |
Make the mounts longer or add a spacer to the chassis.
Ninehigh
| posted on 12/9/09 at 07:20 AM |
How far off the ground is the sump? Make sure the wheels are on it too (something I wouldn't do then I'd have the engine 3ft off the
ground once the wheels are on!)
avagolen
| posted on 12/9/09 at 01:59 PM |
Quote:- How far off the ground is the sump? Make sure the wheels are on it too (something I wouldn't do then I'd have the engine 3ft off
the ground once the wheels are on!)
3Ft sound a bit high to me
Or am I missing something???
[Edited on 12/9/09 by avagolen]
