flak monkey
| posted on 15/9/09 at 08:47 AM |
Duratec alternative flywheel resolved
With some help from beaver34 I have been able to find out what the duratec flywheel I have is.
The part number is:
5S6G-6K390-BA
And it is fitted as std to the 2.0 Focus and 2.0 Fiesta ST. There was a lot of raving about the flywheel on the ST Fezzie when it came out saying it
was a lot lighter than the std duratec dual mass one. This must be the difference.
All the old 220mm clutches fit the flywheel (zetec/cvh) making HD clutches easy to come by, or std ones for normal power very cheap (~£30 for a mondeo
one). I fitted a HD cover plate from an RS turbo which should take 300+bhp.
One word of caution, the flywheel is slightly smaller than the dual mass on the mondeo. The fiesta, focus and mondeo all use different starter motors.
So unless you want to mod the motor (easy enough) you need a starter from a fiesta ST as well.
Hope that helps
[Edited on 15/9/09 by flak monkey]
Sera
http://www.motosera.com
big_wasa
| posted on 15/9/09 at 11:19 AM |
Oh that makes my cvh fly' worthless then
flak monkey
| posted on 15/9/09 at 11:26 AM |
I reckon that would fit too, but the ring gear would need to be moved.
Sera
goaty
| posted on 15/9/09 at 12:08 PM |
David, do you have a part number for the pressure plate you have??
I think i it will fit on my Titan flywheel too.
thanks
flak monkey
| posted on 15/9/09 at 12:32 PM |
thanks
I dont think it will as your titan one is for 215mm clutches and this is a 220mm.
My cover plate is a CP5905-2. The bolt and dowel holes are on a 242mm PCD. 230lb/ft torque capacity.
The Duratec (aftermarket - Titan, Raceline etc) pressure plate is a CP5905-1 which is actually for an MG ZR 160 with a torque capacity of 178lb/ft.
I am not aware of another pressure plate which fits the titan/raceline flywheels at the moment with any higher torque capacity. But now you know what
car its designed to fit you might be able to find something?
Sera
goaty
| posted on 15/9/09 at 04:48 PM |
That is very ahndy thanks. Hopefully, Scholar may be able to give me some guidance, just waiting to hear back. And just tried a CVH pressure palte nad
you are correct, it was too small.
Hopefully something wil turn up.
beaver34
| posted on 15/9/09 at 07:35 PM |
im good freinds with jon fom shawspeed who has done many a duratec to type 9 conversion, can find out what he uses if you wish
goaty
| posted on 16/9/09 at 12:16 PM |
If you could ask it woudl be great. I am using a Titan 8.5inch flywheel. Got a AP friction plate, just need a pressure plate.
Been reading that the Rover turbo ones may owrk but its finding one as i dont want a whole kit.
cheers again
joe
flak monkey
| posted on 18/9/09 at 04:48 PM |
Realised i made a cock up with the part number here.
My clutch cover is a CP3560-2 not what I said up there ^^^^^ !!
Anyway, I have added full details to the duratec thread.
Sera
