posted on 16/9/09 at 11:35 AM |
connecting exhaust
In order to use my R1 can, I need to get e piece of exhasut tubing and connect to existing system.
I have a 90 degree stainless bend that is 50 mm O.D.
I am looking at somehting like this:
10 degree stainless pipe, available in 2 in and 2.25 inch diameter but not sure what size would be best.
The 2 inch would need to be stepped down to fit inside the 90 degree bend and the 2.25 inch I think will be a bit too loose over the 90 degree bend,
altough I could weld that up in theory with a sleeve inside.
So what would you recommend?
A1
| posted on 16/9/09 at 11:48 AM |
what size is the inlet to the R1 can? Id just do it that size...
chris_smith
| posted on 16/9/09 at 11:49 AM |
are you after a stepped sleeve? this guy does them on ebay very quick delivery next day virtually any size dia
linky
| posted on 16/9/09 at 11:50 AM |
way too big - 60 mm. do not want many steps in the system if I can avoid it.
^^^^ pipe-werx - same peeps as my photo - you can read it in the backgorund
I am thinking it would be best to get a 2 inch 10 degree pipe with a 90 degree bend but that would need to be a special - he does both but as separate
pieces.
[Edited on 16/9/09 by 02GF74]
Gary 7
| posted on 16/9/09 at 06:32 PM |
I purchased a pipe from pipe works and they can reduce or enlarge the ends to various sizes just tell them what your looking for.I found them very
helpful.
