gregs
| posted on 17/9/09 at 02:46 PM |
Type 9 V6 - Is this right???...
Hi all,
Have fitted my spacer to my V6 gearbox and bolted back up with the pinto bellhousing, and am a little confused - the input shaft still sticks out past
the front face of the bell housing.... I was expecting the spacer plate to put it in the same position relative to the front face as it is with the
Pinto g'box. What is sticking out is the the non-splined section - any thoughts?? - did everyone else have this who has converted?
Greg
matt_claydon
| posted on 17/9/09 at 02:49 PM |
I'm pretty sure the input shaft protrudes pround of the bellhousing flange on a normal type 9 doesn't it?
I vaguely remember my old one not sitting lfat on the ground when I tried to stand it upright on its bellhousing.
[Edited on 17/9/09 by matt_claydon]
rallyingden
| posted on 17/9/09 at 02:56 PM |
My Standard type 9 sits flat on the floor on it bell housing i.e. the input shaft does not protrude. However this is a standard box not set up for
V6
RD
blakep82
when i put the vauxhall bellhousing on my type 9, it sticks out by about 10mm. don't know if that has any relevance to pintos or not, but mine
does anyway
________________________
gregs
| posted on 17/9/09 at 03:02 PM |
Only spotted it coz the one I've taken out sits flat and the V6 needs chocking off the floor....
flak monkey
It should stick out a bit yep.
Not much, maybe 10mm
Sera
http://www.motosera.com
r1_pete
| posted on 17/9/09 at 03:06 PM |
My MT75's stick out about 10mm, and the MT75 and T9 are interchangable on the zetec, so I'd expect the same protrusion.
gregs
| posted on 17/9/09 at 03:07 PM |
ah good - cheers flak, is sticking out almost exactly 10mm..... I'll stop worrying.
Liam
| posted on 17/9/09 at 03:48 PM |
Only start worrying if it doesn't fit on the engine
