Author: Subject: honing
omega0684
posted on 19/9/09 at 06:05 PM Reply With Quote
honing
can someone explain the steps to deglazing/ honing a cylinder bore please.
Ben_Copeland
posted on 19/9/09 at 06:10 PM Reply With Quote
OOooo was wondering this myself.
Remembers to check Receive Email Notifiations....
Ben
Locost Map on Google Maps
Enter Your Details Here
flak monkey
posted on 19/9/09 at 06:14 PM Reply With Quote
Step 1 - Buy honing tool
Step 2 - Set tool for bore size if required
Step 3 - Select suitable drill and set speed nice and slow, mount honing tool
Step 4 - Slide tool into cylinder bore and start the drill, nice and slow. Work the tool up and down the bore fairly quickly without twisting it.
Your aim is to get an even, matt, cross hatched type appearance over the whole length of the cylinder walls.
Engine needs to be totally stripped before you start as well. Otherwise you will end up with bits of metal and grit everywhere.
There are several types of honing tool available, from ones with 3 stones on legs, to ones which look like flap wheels. All will work.
Sera
http://www.motosera.com
omega0684
posted on 19/9/09 at 06:19 PM Reply With Quote
cheers dave, legend as usual!
posted on 19/9/09 at 06:24 PM Reply With Quote
A brand new piston ring will only actually touch the bore in 3 or 4 places around its circumfrence.
The piston rings need a slightly rough surface so they wear (bed) in to exactly fit the curvature of the bore.
The rough surface texture also allows the cylinder wall to retain an oil film which is vital to prevent hot spots forming on the piston rings during running in.
If the piston ring locally over heats it looses its spring tension and won't be held against the bore to form the initial seal.
Although gas pressure behind and on top of the ring is what actually push the ring out to form the seal, it is vital there is enough spring tension in the ring to allow the pressure to build.
With a worn bore thre is the added problem of the top piston ring hitting the wear ridge made by the old ring at the top of the bore, so the wear ridge should be honed smooth before fitting new rings.
philw
posted on 19/9/09 at 06:26 PM Reply With Quote
You're looking for between 30 and 45 deg angle on the honing marks
Must try harder
Ben_Copeland
posted on 19/9/09 at 06:31 PM Reply With Quote
That cant be easy to master !!!
Ben
thunderace
posted on 19/9/09 at 06:43 PM Reply With Quote
http://www.youtube.com/watch?v=82OMO1ArSkk&NR=1
MakeEverything
posted on 20/9/09 at 10:42 AM Reply With Quote
Did i read somewhere that with new rings, because of the cross-hatches on a new bore the harder the engine revs the better for the first few miles? This is so that the cross hatching and rings press hard against eachother (or the rings against the hatching), matching them before the bore becomes smooth again?
Makes sense to me, but i know that manufacturers insist on a running in period (or used to).
This will open up a nice debate, but logic does suggest that if an engine is run in hard, it seals better in its bores?
Kindest Regards,
Richard.
MakeEverything
posted on 20/9/09 at 10:46 AM Reply With Quote
http://www.youtube.com/watch?v=ZOAdIQsWoPM&NR=1&feature=fvwp
Rebuild a zetec in one minute!
Kindest Regards,
Richard.
posted on 20/9/09 at 11:38 AM Reply With Quote
As an apprentice I was taught to oil pistons, rings etc on assembly but it seems that may have been the wrong approach? I remember reading, possibly in the old CCC magazine assembly just using WD40 on the pistons allows to rings to bed in better. When I rebuilt the engine in my car I did try this method and can say I'm pleased with the engine BUT if you try this don't blame me. Also seem to remember race gearboxes being run in filled with Brasso to bed in the gears before final rebuild?
posted on 20/9/09 at 12:15 PM Reply With Quote
When I was a marine apprentice with BP I worked for a few months in the long gone Isle of Grain oil refinery. After overhauling big gas compressors they added a self destroying bedding in compound to the oil, the idea was the bedding in compound disappeared to nothing after a few hours running and you didn't even have to change the oil . Although it looked like sulpher powder and looked like Brasso when you mixed with oil to add to the sump it was very special stuff and imported specially from the USA.
The Brasso in the rear axle trick was an old Colin Chapman dodge learned from his secondhand car dealing days, it fixes final drive noise due gear problems but ruins the bearings.
[Edited on 20/9/09 by britishtrident]
posted on 20/9/09 at 12:19 PM Reply With Quote
Found this
http://www.bunkering.co.kr/bp/products/H15_BP_RUNNING_IN_COMPOUND.htm
posted on 20/9/09 at 12:45 PM Reply With Quote
^^^ wot the monkey said.
you are aiming to cross hatch the bore, around 45 degrees or a bit less ot the horizontal.
old skool honing is done by hand using 600 wet'n'dry and will work just as well s the cheap DIY honing tools.
and that is fine on loose tolerance engine, oi.e. old ones such as pinto, crossflow .
modern engines are built to much tighter tolerances e.g zetec and the honing is to two stage process - the second one smoots of the bumps left by the coarser first stage and is probably harder to replicate at hone. (<--- geddit?).
googl will provide you with more info. as well as any correctrions to the above.
posted on 20/9/09 at 12:55 PM Reply With Quote
Heard about the strips of heavy duty plastic bags in the diff to sort out noise
posted on 20/9/09 at 01:08 PM Reply With Quote
600 grade is much too fine it will polish the bore --- to get the rings to bed in the bore has to be surprisingly rough 120 grade Emmery is nearer the mark.
