speedyxjs
| posted on 23/9/09 at 11:08 AM |
Coolant reservoir rules
Just want to check before i take it further, am i right in thinking the coolant reservoir has to be transparent and hold at least one litre?
A1
| posted on 23/9/09 at 11:10 AM |
unless its been changed since IVA came in, no. mines aluminium and holds about 500ml
speedyxjs
| posted on 23/9/09 at 11:12 AM |
Cool, that means i will be able to use my power steering reservoir as it is black and about 300ml but the outlets are the right size
Mr Whippy
| posted on 23/9/09 at 11:16 AM |
You’re just making up new rules now
matt_claydon
| posted on 23/9/09 at 11:18 AM |
There are no requirements for coolant reservoirs - it's not safety or environment related.
The washer bottle must be at least 1 litre but there's no requirement about being transparent.
Bluemoon
| posted on 23/9/09 at 11:34 AM |
No rules, but remember water expands about 4% by volume from 20 to 100C...
So for 300ml expansion space the most coolant would be 300ml*(1/1.04)= 7.5 ltrs..
And that's without any air in the system..
My CVH has around 9ltrs; I guess the Jag engine must be similar? You are going to need a 1ltr or more to get it to work unless you have a separate
expansion bottle on the pressure cap outlet..
Dan
[Edited on 23/9/09 by Bluemoon]
