gavin174
| posted on 27/9/09 at 08:57 AM |
zx6 carbs yet again
have a set of zx6r carbs on a pinto
been rolling roaded any they aborted run due to running to lean
have read other posts about blanking vacuum jets, but not sure where they are..
this is a pic i have pinched off another post and are zx9 but look very much the same..
can anyone confirm what they have done with this pipe.. is it the one i need to blank..
thanks gavin
cd.thomson
| posted on 27/9/09 at 09:03 AM |
Hi gavin, I haven't fitted mine yet, but asked this question the other day (for zx9rs).
you have to leave these open to the air, although should fit a filter on the end to stop crud getting sucked in. If you don't the fueling goes
at the window.
I believe its the air bleed jets you need to block, but I haven't a clue where these are - a google reveals nothing for zx9r carbs
Craig
whitestu
| posted on 27/9/09 at 09:14 AM |
Leave the pipe open - it doesn't affect the mixture on ZX6 Carbs.
What have you drilled the mains to, and what notch are the needles on?
On my 2.0 Zetec I have 1.6mm mains with the needle on the lowest [i.e the richest setting] notch. If anything that's a little bit on the rich
side.
I haven't made any other changes to my carbs - mine are re-spaced so don't even have the pipe.
What air filter do you have?
Stu
[Edited on 27/9/09 by whitestu]
gavin174
| posted on 27/9/09 at 09:24 AM |
the carbs are as "standard" supplied by GBS...
ready jetted for a pinto on there manifold with pipercross sausage filter.
whitestu
| posted on 27/9/09 at 09:31 AM |
Best to either ask them what the jet sizes are or take one out and measure it - some small drill bits are an easy way of doing this and are cheap
enough to buy.
The jets are easy to remove.
Stu
ashg
| posted on 27/9/09 at 10:48 AM |
unfortunatly i dont think gbs have managed to ever supply a set of carbs for a pinto that are correctly setup. mainly because its almost impossible
to do.
under ther big air inlet holes on each carb there is a little hole. you either need to block them off or restrict them down to a smaller size.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
col
| posted on 27/9/09 at 04:41 PM |
Hi Gavin, ive got zr6 carbs,have you fitted anything to the pipe outlet at bottom of carbs in the middle?
My carbs arent fitted to anything yet but will be going on a zetec 1.8
regards col.
tul214
| posted on 27/9/09 at 05:45 PM |
The picture is of Jacko's carbs. send him a u2u and I am sure he will help.
1.6 Raw Super6 sold
whitestu
| posted on 27/9/09 at 07:00 PM |
As I said in my previous post, all you need to do to ZX6R carbs is bigger jets and fiddle with needle position to get midrange mixture right.
Nothing needs blocking up - I think this just applies to ZX9 carbs.
I've fitted a couple of sets on 1.8 and 2.0 Zetecs.
Stu
