franky
| posted on 30/9/09 at 12:10 PM |
quick question...
would I get away with using 32mm hosing on a 30mm connection if I made sure it was properly secured
Mr Whippy
| posted on 30/9/09 at 12:12 PM |
wrap the connector in some PTFE tape
blakep82
| posted on 30/9/09 at 12:13 PM |
and a good tight hose clamp
________________________
| posted on 30/9/09 at 12:15 PM |
probably - try it and see
can you get 2 hose clips on it - might help close it up a bit better
rallyingden
| posted on 30/9/09 at 12:19 PM |
As per CBS tip of the month.
Cut apiece of Bicycle innertube and stretch that over the smaller tube, more than on if needed then connect hose & tighten.
RD
craig1410
| posted on 30/9/09 at 12:24 PM |
Use self-amalgamating tape if possible. You can get some quickly by buying a hose repair kit from halfords. It includes two reels, one is reinforcing
tape and the other is self-amalgamating tape. Just make sure to stretch the self-amalg tape as directed otherwise the adhesive is not activated.
Craig.
Mr Whippy
| posted on 30/9/09 at 12:35 PM |
RD
good tip
franky
| posted on 30/9/09 at 12:51 PM |
cheers all
speedyxjs
| posted on 30/9/09 at 01:20 PM |
I had to use a 2mm bigger hose on a smaller connector and just put 2 jubilee clips on.
No probs so far
