Author: Subject: Heater Feed / Return pipes
rallyingden
posted on 6/10/09 at 09:16 AM Reply With Quote
Hi getting to the plumbing stage and was wondering what to do with the feed from the engine, pinto, to the heater and the return.
Can I just blank them off at the cylinder head and water pump connections, don't really want to run a hose from pump to head.
RD
tegwin
posted on 6/10/09 at 09:29 AM Reply With Quote
Are the heater connections for the pinto not on the inlet manifold and the pump?
But yes, you could just blank them off, or connect them together...
www.verticalhorizonsmedia.tv
rallyingden
posted on 6/10/09 at 09:31 AM Reply With Quote
Yeah the connection is on manifold but that is only a port to the cylinder head.
Just bothered about the result of losing "some" flow.
RD
tegwin
posted on 6/10/09 at 09:43 AM Reply With Quote
I cant see how that would be an issue...
I have a heater valve on my heating circuit and it spends most of its time closed... it has a tiny tiny bypass duct in it that is about the size of a matchstick.....
Other than that, its closed... and I cant see it passes that much water
AndyGT
posted on 6/10/09 at 09:56 AM Reply With Quote
but the air trapped MAY be an issue.... ...maybe blank the manifold and use a bleed valve or something to get rid of most if the air?
nothing is impossible
everything is possible
posted on 6/10/09 at 10:51 AM Reply With Quote
Ford Pinto heaters were air blending heaters the coolant flows constantly though them acting as the by-pass cooling circuit. You must have the by-pass circuit connected
rallyingden
posted on 6/10/09 at 11:06 AM Reply With Quote
MMmmm Thats what was worrying me, wasn't sure how the coolant would flow round the cylinder head as the only way in & out with the heater circuit blocked would be the block to head ports.
Pipe to water pump it is then.
RD
tegwin
posted on 6/10/09 at 01:59 PM Reply With Quote
Hmm... looks like I need to go re-plumb my engine then
